need help is my turbo rebuildable?
Old May 14, 2015 | 01:21 PM
planetx's Avatar
Default need help is my turbo rebuildable?
i have an old turbonetics t3t4e 57 trim small shaft turbo.after verifying done by turbonetics they told me that they no longer make parts or rebuild kits for.so im wondering if any of you turbo experts know of any rebuild kits are available and if so who makes them.any help greatly appreciated.
Old May 14, 2015 | 01:41 PM
TheShodan's Avatar
Moderator
Default Re: need help is my turbo rebuildable?
how old is old? Pre-2000? Some shared with Garrett, others, from Turbonetics only.
Serial numbers? pictures? etc..
Old May 14, 2015 | 01:47 PM
planetx's Avatar
unsure of exact age im not original owner.the numbers on the. blue backplate are t-12609.the turbonetics rep said "it is a very early generation turbo and it is coming up as a t3t4e 57 trim". as for pictures i cant figure out how to post them.if you have an email u can pm me i can send pics that way if you have time.
Old May 14, 2015 | 02:48 PM
planetx's Avatar
Old May 14, 2015 | 07:33 PM
TheShodan's Avatar
Moderator
Originally Posted by TheShodan
yes. That number is just for the back plate itself, and not for the designation of the entire turbo. You have no other option than to send it into a rebuild facility to find out if it can use Garrett or other company parts
Old May 15, 2015 | 04:21 AM
SharkRacer's Avatar
An old and small t3/t4 is almost never worth rebuilding. Most places will charge $350-450 to rebuild, plus yours and their shipping costs ($20 each way). That is with NO parts needed additionally. You most likely will need new parts. After all is said and done, you could get a new turbo for the same price or $100 more.
Old May 15, 2015 | 06:05 AM
TheShodan's Avatar
Moderator
I have to agree with SharRacer here. You're easily looking at about 350-400 dollors just internal parts and labor, without any work or changes of wheels or shafts or anything. Although I would say it would take a bit more than $550 for a new quality turbocharger to replace that.
Old May 15, 2015 | 12:46 PM
planetx's Avatar
I havent found anything quality for less than 900.this turbo pulls really nice and has no noticeable shaft play,the only issue is the oil visible in the inlet and a bit of smoke after boosting when i let off.i have one more hope ..the turbo oil return line fitting on the oilpan is bent /crimped to half the diameter its supposed to be.thanks for the advice
Old May 15, 2015 | 05:26 PM
planetx's Avatar
Took oil return hose off and got close pic of oilpan fitting...looks like somebody cramped the fitting sabotoge...
Old May 15, 2015 | 06:00 PM
TheShodan's Avatar
Moderator
If it works, then keep it, and check the oil fittings and return lines. And its true. 800-900 is about what you're going to pay for when it comes to the quality stuff.
But I have to admit. that oil feed line at the feed fitting seems.. odd. what are you using?
Old May 16, 2015 | 08:09 AM
planetx's Avatar
thevpic of the crimped/bent fitting is the oil return fitting on the oiloan.and the feed line iam unsure of what brand but it looks similar to the one goautoworks uses.
Old May 16, 2015 | 11:09 AM
TheShodan's Avatar
Moderator
I'm not talking about the oil feed line itself. its the integrated fitting that goes into the turbocharger that seems to need attention as well as the return line.
If you don't get these two items in order, it doesn't matter whether or not you rebuild your current turbo, leave it alone, or buy something else. you're going to have a problem.
Get that nonsense fixed before trying to boost.. you'll save a lot of time, money, and headache. start searching about feed line fittings and what to use.
Old May 18, 2015 | 02:19 PM
planetx's Avatar
Iv read up on oil feed and return lines and fittings,and i dont see whats wrong with the fitting on the feed line.im probably missing something obvious..appreciate if you could help me out shodan
Old May 18, 2015 | 02:23 PM
TheShodan's Avatar
Moderator
That picture doesn't help much, add I need to know what feed line size and fittings you're using in there..maybe it's the lighting or something.
But the return line looks a lot worse.
JaGuAr81
Dec 12, 2012 03:12 PM
Rickdrizzle
Apr 12, 2008 12:23 PM
DCivic00
Nov 28, 2004 02:02 PM
HFsleepa
May 28, 2004 07:34 AM
