need help is my turbo rebuildable?
i have an old turbonetics t3t4e 57 trim small shaft turbo.after verifying done by turbonetics they told me that they no longer make parts or rebuild kits for.so im wondering if any of you turbo experts know of any rebuild kits are available and if so who makes them.any help greatly appreciated.
Re: need help is my turbo rebuildable?
unsure of exact age im not original owner.the numbers on the. blue backplate are t-12609.the turbonetics rep said "it is a very early generation turbo and it is coming up as a t3t4e 57 trim". as for pictures i cant figure out how to post them.if you have an email u can pm me i can send pics that way if you have time.
An old and small t3/t4 is almost never worth rebuilding. Most places will charge $350-450 to rebuild, plus yours and their shipping costs ($20 each way). That is with NO parts needed additionally. You most likely will need new parts. After all is said and done, you could get a new turbo for the same price or $100 more.
Moderator
I have to agree with SharRacer here. You're easily looking at about 350-400 dollors just internal parts and labor, without any work or changes of wheels or shafts or anything. Although I would say it would take a bit more than $550 for a new quality turbocharger to replace that.
Moderator
I havent found anything quality for less than 900.this turbo pulls really nice and has no noticeable shaft play,the only issue is the oil visible in the inlet and a bit of smoke after boosting when i let off.i have one more hope ..the turbo oil return line fitting on the oilpan is bent /crimped to half the diameter its supposed to be.thanks for the advice
But I have to admit. that oil feed line at the feed fitting seems.. odd. what are you using?
thevpic of the crimped/bent fitting is the oil return fitting on the oiloan.and the feed line iam unsure of what brand but it looks similar to the one goautoworks uses.
Moderator
If you don't get these two items in order, it doesn't matter whether or not you rebuild your current turbo, leave it alone, or buy something else. you're going to have a problem.
Get that nonsense fixed before trying to boost.. you'll save a lot of time, money, and headache. start searching about feed line fittings and what to use.
I'm not talking about the oil feed line itself. its the integrated fitting that goes into the turbocharger that seems to need attention as well as the return line.
