blackworks oil catch can help
Old May 13, 2015 | 06:33 AM
roll8221's Avatar
Default blackworks oil catch can help
I have a b18c1 turbo and I need to let that biatch breathe a little better, looking into the blackworks can w/ an10 fitting. Pretty sure I know how to install but the question is, there are 6 ports but I think I only need 4 of them. are there 2 other spots to vent I'm not aware of? I know of the 2 in the rear of the block and the 2 to be welded into the valve cover. do I just cap off the other 2? I've done a search on this site, a couple other sites and googled it multiple times, the only info I get is for the smaller cans with 2 ports... any suggestions? ...Thanks in advance...
Old May 13, 2015 | 09:45 AM
v4lu3s's Avatar
RTFM
Default Re: blackworks oil catch can help
Info@bwrusa.com
Old May 13, 2015 | 12:18 PM
roll8221's Avatar
Thanks chief... The number for customer support is 623-907-3480... for anyone looking for the same information in the future, They make a 4 port model which would be the appropriate one. If you do have a 6 port you would install 4 from the valve cover and 2 to the back of the block. Otherwise, just 2 to the valve cover and 2 to the back of the block... and props to v4lu3s for the email address which can also be found on the website. I will try to post pics of the install, again for future reference.
TravisBiggie
Jul 3, 2012 10:48 AM
blackeg
Apr 5, 2011 04:48 AM
lll_fusion_lll
May 20, 2010 05:55 AM
Mr. Em1
Welding / Fabrication
10
May 2, 2009 03:38 PM
Cyphear
Dec 29, 2008 02:07 PM
