cast manifold suggestion
here's the setup:
motor: B18c1 CSS block, LS crank, gsr head, gsr cams, 10:1 Mahle pistons, Manley H-beams
Turbo: Hy35 holset
Want to make 400ish whp. What's a decent cast manifold for this goal? Trying to be cheap and reliable for daily use. Are the SPA manifolds decent? I'm just not sure what has been proven to flow well with good wastegate placement as well.
Turbo: Hy35 holset
I completely agree. Most cast logs for these engines are for 5 bolt FORD style turbine housings.
Using an SPA top mount requires you to use a special clocking flange, and in some cases, depending upon turbo, you have to cut the hood of the car..
Oil return line rotting can get a little tricky unless making your own..
So even when it's cheap, costs increase in other areas
For a vtec head go with a tubular equal length manifold. If you just want a cheap cast manifold that will work ok but definitely not ideal you can get them on eBay for $60 shipped. That's what I have on my ls turbo and it works fine for my goals. Vtec head is best matched with an equal length imo.
1988 1991 Honda CRX B16 B18 B20 Engine Cast Iron Honda B Series Turbo Manifold | eBay
This is the exact one I'm running. Wg placement is good, no boost creep issues at all. I'm also running it with a 4 bolt hotside (precision 5431e) and 3" dp with the compressor on the driver side. I did have to move my radiator over about an inch to clear the dp. Again this will work ok but if funds are available go with a equal length instead.
I guess I should also say that this is going into an EK civic.
I definitely refuse to believe that 400+whp can't be made with a plethora of cast manifolds out there.
Didn't Evan's tuning go 9's on an inline pro manifold?
I absolutely refuse to go with a tubular manifold. I drive this car 60 miles a day and I already have tons of money wrapped up in my mr2 drag car's tubular divided t4 manifold. I only have enough budget for one drag car.
I'm just trying to pep up my daily driver on the cheapo. Hence the use of an HY35 turbo. I'm not gonna run a $150 turbo on a $750 manifold.
I'm basically just trying to figure out what manifold will work with this holset and flow enough for a decent amount of power. The inline pro manifolds look nice, but too pricey for my goal.
I do like the SPA top mount, but I'm not sure if the compressor will clear the hood on this holset. This guy is pulling it off in his integra. https://honda-tech.com/attachments/f...-integra-3.jpg
What about the SPA bottom mount? Or the CX racing?
Honda B Series Turbo Manifold - spaturbousa
http://www.ebay.com/itm/B-SERIES-B18-B18C-B16-GSR-SI-CAST-IRON-TURBO-MANIFOLD-/290555932996?hash=item43a67bb144&vxp=mtr
I never said a spa manifold or a cast manifold wouldn't work . But I'm sure you can find a tubular log manifold for cheap. Also I've found a mini ram set up for 300 bucks before .
Check out the HT marketplace. There's a pretty healthy range of options there. Personally, I'm eyeballing DNA's Blurr manifold. I'd hope $138 for the manifold plus $60-$70 for the downpipe would be within your budget, or you may need to re-evaluate your goals.
Forced Induction - Honda-Tech
Mini rams are nice, but still more prone to cracking than a cast manifold. I can't think of anything worse than a pipe style log manifold, though. All of the unreliability of a welded manifold with even worse flow than a cast manifold and still more expensive. It's a lose lose lose.
A couple reasons: 1: I don't have time. 2: it would still cost me more money in materials 3: it would still be less reliable.
I can afford something nice if I wanted, but I don't need anything nice to make 400whp. The money I save here can go towards something else or better yet, go towards my 9 second mr2 goal.
I really didn't even want to do this project, but the Honda scene around STL is truly sad. I've seen H22 swapped hatches run upper 14's at like 91mph. **** that doesn't even make sense like this kid around town that had a crappy LS swapped hatch with a couple bolt ons that would somehow beat vtec b series swapped crx's that were a few hundred pounds lighter with probably 30 more hp. It's just that nobodies stuff ever runs right because they can never scrounge up the last couple dollars to make it correct.
It's depressing.
So I decided to show them how it can be done for very very little money. That is the purpose of this build. 400whp for the least amount of money. So far, I'm doing pretty good. I buy parts in bundles and then sell what I don't need. As of now, I have: B18c1 block, LS crank, oil pan, GSR intake manifold, TB and cams for a net total out of pocket of $65 LOL. I got a set of NIB Mahle pistons and some good used Manley H beams for $400 total. The CSS and machine work is being paid for with some old k24 blocks that I had laying around that had already paid for themselves. Traded a pair of old slicks for a GSR transmission. I'm converting a $20 obd1 ecu (auto non vtec) to be ready for Hondata and I got a jumper for free. Holset is $150 and I have some random duramax piping that I bought at a swap meet for $1 a pipe (70 pipes with t bolt clamps and couplers) that I'll be using.
I mean, this really is gonna be the cheapest build ever. So I need to buy an appropriately ridiculously cheap turbo manifold.
Ok, now this is funny... That's a SPA bottom mount replica for $25 new. ROFL wonder if that'll work?
http://www.ebay.com/itm/Cast-iorn-Honda-TURBO-MANIFOLD-Wastegate-Acura-civic-integra-b16-b18-/221766249620?hash=item33a24c6c94&vxp=mtr
Comments in blue. I think I have to make this post a "pop-up" book style, with lots of pictures and simple explanations so that people can visualize these items and get on the same page. No disrespect to anyone, but sometimes, you gotta go back to basics to come to common ground.
Don't expect to bolt up with either of these, as they never had the HY Holset in mind. Again, Garrett-Styled turbos. But if you try it, be prepared to do some serious work to get it to fit. Not a lost cause, but.. you have to be willing to do what it takes.
*sigh*Sorry for the book all, but OP , you just have to dig deeper than what you're doing and ask yourself what you're willing to do once you get the answer to these.
*edit* shortly after posting this, I saw efHondefender's response to NotARacist and his reasoning behind this.... I now see I wasted my time as he's going to continue to post up these cheap manifolds asking if they work.. ..
My apologies for wasting everyone's eyeballs
Absolutely it can support that level, and even more. But there's tubular equal length (unnecessary) and tubular log manifolds, which is configured differently than these nickel-iron log manifolds that you're talking about
Tubular Steel Log manifold -good idea can hold 4 bolt or 5 bolt turbos and is less forgiving for Holsets unless a custom downpipe can be fabricated to work with its flanging system, or downpipe adapter.
So, you can run this
or
this
as long as you use a 4 bolt style or v-band style turbine housing like this
Nickel-Iron Log manifold - these don't fit so well unless they are 5-bolt Ford Style turbine housings. They seat the compressor cover closer to the engine which makes it difficult to fit a Holset, or any other turbocharger unless it is a Garrett-styled turbo.
so your turbo must have this
[img]http://www.forcedinductionsonline.com/image/cache/data/Garrett_GT28-T3(1)-500x500.jpg[img]
In order to run this
or the eBay **** that looks like this
With that low cost like the eBay one, that's more suspect than anything. There's such thing as being on a budget and being a cheap-***, which just makes things worse.
You don't want to run an SPA Top mount manifold with an HY35 on most civics or Integras due to clearance issues.
I know you want to see this
But you'll more than likely have this
which only YOU can be the judge whether or not you want that. No one is passing judgment, just showing you what you'll have.
that manifold is an entirely different animal, both in material and configuration.
(most were made for 5-bolt Ford style turbine housings using Garrett styled turbos
They came in either a carbon stainless steel alloy, or a cast iron design with a lot of nickel to keep it together
So.. again, you're thinking of this
But they also have this
As a T4 model. this one only came as a Carbon stainless steel version.
The Inline Pro manifold isn't your run of mill "cast manifold". yes it was all in one cast mold piece, and not like tubular steel, but that was FAR FAR FAR from what you're comparing the eBay garbage to, both in quality and in price. This manifold is more akin to tubular log manifolds and "equal length mini-rams" than anything in eBay. So don't think that your eBay cast will endure "9 second runs" in either power or utility compared to Inline Pro.
These were NOT made for any of the Holset series at all, and from the angle of the turbine housing inlet flange, you'd have a horrible time making it fit properly. Not saying it can't be done, just that it really shouldn't be done due to amount of BS involved.
You mean Kooks-style manifold (aka "Ram Horn") as a tubular manifold. Again, you gotta be specific with what you say. that is different from a "tubular log".
You're thinking boosted94gsr means this
And you're right, it isn't remotely necessary, as this is overkill. But what I think boosted94gsr means is simply using a better quality exhaust manifold made of tubular steel and better materials to avoid garbage issues later. They can be repaired with a competent welder should something happen, but because of the better welding abilities and processes of the more popular companies, you're less likely to come up with issues than the eBay ****.
So, in other words, boosted94gsr is stating something similar to phaphon. Using this
instead of your idea from eBay. You get what you pay for.
That's fine. Because it more than likely wouldn't have fit well anyway. You're going to have to own up to the possibility that you do one of two things.
1) Get a crap manifold from eBay, hope for the best, fabricate and alter the block to fit your Holset (which they weren't designed for), and hope for the best, knowing you run the risk of destroying the manifold, which since its so cheaply made, can't really repaired, or
2) Get something a bit more quality, including the possibility that it may have to be fabricated from scratch, invest in better materials and less risk of destruction, but be more assured that very little will go wrong
And that's fine and dandy, you can do that. But he also fabricated his downpipe to fit and not use a clocking flange. This goes back to whether or not you are willing to have things fabricated.
There is someone right now (DA-NINE with his HY Holset "oddball" setup) that followed this same approach. He's even got his thread right below yours.
Oddball DA-NINE Holset thread
Go here and look at his fitment. He customized his downpipe to fit it all. You more than likely have to do the same.
or
this
I've decided that I'd be willing to build my own manifold if I can find someone local that'll let me borrow there's so I can build a jig for flange positions. I drive my car every day, so I can't have it down for me to use it to mock up a manifold.
I can build a manifold off of the motor on the stand if I know where the flanges need to be.
Yeah, there are a decent number of decent options in the marketplace.
Also, Shodan just hit you with a wall o' text, but you really should read all of it. Dude knows his **** - he won't steer you in the wrong direction. There's a big difference between "cheap and effective" and "cheap for the sake of being cheap". Cheap for the sake of being cheap will leave you broke, after you've had to buy a replacement for the same part three times in a row. Affordable quality over "lol $25" any day of the week.
Sometimes you have to be wordy to get all of your thoughts down on paper (or a screen, or...whatever medium you're working with).
Also, you aren't the only two with triple digit typing speeds
Ok I get it. You guys are probably very used to dealing with broke kids with no money and even less know how.
Please do not confuse me for that. I'm a 34 year old man with a tig welder and a band saw along with any other tool I could need for this project. I restore corvettes from the ground up and they sell on nationally televised auctions.
Dealing with problems is not an issue for me. Building my mr2 drag car is 52.589 thousand times more difficult than trying to figure out how to get a Holset hy35 on a bseries honda.
This is what I was hoping for when I made this thread... "sure guy. so and so used xyz cast manifold with a holset and it cleared just fine and made world ending whp"
I knew it wouldn't be that simple, but I tried anyway because I was getting tired of google searching. Although I think my question has been answered in that build thread link that Shodan gave me.
Just for fun though, what do you guys really think is so much different about a $150 name brand cast manifold and a $85 ebay replica? Obviously, if we were talking about hand built stainless tubular manifolds, then there are huge quality differences, but that's not what we are talking about. We're talking about nodular cast iron poured into a sand casting. I could probably make one in my back yard if I had someone's name brand manifold to make a mold from and it would do the exact same thing. I bet that $25 SPA bottom mount knock off works every bit as good as the original. Maybe there are mild QC discrepancies, but nothing that would matter too much. Especially considering the price difference.
That said, I'm not condoning cheap chinese products in general. I absolutely will not buy a tool from harbor freight. I just think that the durability of chinese cast iron manifolds are not really of great concern. My last tubular, equal length manifold that I owned was a Greddy piece from a very rare and very expensive old T78 turbo kit designed for an MR2 3sgte. It was cracked to hell and back from a couple years of use. And not just the welds. Actually, just about everywhere except the welds. It had radial cracks running around the primaries in places. It's funny what heat cycles in extremes can do to a bunch of separate pieces of pipe welded together all trying to move in different directions with stresses built in from the initial fabrication. I'd be willing to bet on that $25 cast manifold lasting longer without cracking than most of the tubular manifolds on the market that cost over 20x the amount. Not that a cast iron manifold won't crack. Factory 3sgte and 4g63 manifolds always crack and they had a way more money dumped into the design of those than any of these aftermarket offerings have. So again, what difference does it make. The only one that truly stands out is the inline pro piece, but that's only because it's cast stainless.
Please don't even consider down pipe issue. I'll do whatever it takes for that. I'm not one of those people that order a bunch of parts and expect them to all just snap together like an erector set.
