13s CR NA build?
Has anyone tried doing a super frankiesten b series build?
B18C/B18C1/B18C5 Engine block
B18A/B1-B20B/Z Crank
B18A/B1-B20B/Z Connecting rod
B16B PCT Pistons
OEM 3 layer headgasket (13.33:1 CR)
2 layer headgasket (13.63:1 CR)
1 layer headgasket (14.08:1 CR)
P72 GSR Cylinder head
useing that setup but i was reading something that the b16b head has a more angle valve that shares the same as the GSR head.
While the B16a/itr share the same valve angle as well.
So the gsr head would be best to use with the monsterous dome pistons of PCT & bump the compression more. Is this true has anyone done it ? Any feedback would be nice. and yes i know i left the head internals out.
B16B PCT Pistons
pcts in a b18c block with p72 head are close to begin with. Theres plenty in the all motor section about that. Adding LS crank and rods will make it worse. Search for "GSR PCT" or whatever in the all motor section
Well i want a High comp engine p30/p73-00 will only get me at about 11.7-8:1 CR With a LS crank and rods.
A stock b18C R will make stock 11.7:1 CR correct me if im wrong. So i want something better to go further then stock
In b18c with b18c rods with pctx pistons u get 12.8:1 with 3 layer headgasket and pr3 head. That is enough cr to make much power. With pro2 cam u make over 240hp.
ko2performance
Engine Machining & Assembly
Mar 15, 2016 10:03 AM
jaydem_ekizzle
Sep 8, 2006 08:05 AM
