00 Civic Coupe passenger power window not working. spent 2 days t/s so Pls help!
Hello. I have a problem with my passenger side not rolling up and down from both master and passenger switch.
I'm almost getting to that point to take the car to an electrician. I have a 2000 honda civic ex coupe that the passenger side window will not roll up even after all fuses have been checked.
So far this is what i have done and found:
-Direct jumped power from battery to the 2 wires coming out of window motor and the window DOES go up and down.
- I test continuity of both master and passenger side switch terminals and is ok (i hope)
can any one walk me through this? any auto electricians?
I look through you tube and searched. People seem to have different problems.
I found the problem. After looking at the manual diagram I realized that there is a blue/yellow wire from master switch to passenger side switch and it has no continuity. Luckily I got a jumper wire long enough to touch both switch and I was able to work the passenger side window. Whew..I called around and they were charging$80/hr min.
Now I just got to find out where that short circuit was so I can slice the wires together. I would hate to boot legged the wire across. Thank you guys anyway. Mods, I give you permission to delete this unless thread.
DelSolDon
Apr 30, 2017 03:52 PM
orestrus
Honda Civic (2001 - 2005)
Apr 3, 2011 07:02 PM
red civic standard
Jun 26, 2009 07:41 AM
