2002 honda Civic with P1457 and P0137
I just had the head gasket replaced on my daughter's 02 civic 1.7 vtech and now it is throwing P1457 and P0137...
Any help would be much appreciated!
Sorry for not responding sooner! I posted and then left on vacation for a couple weeks...anyways, fuse #4 is fine...any other thoughts?
Unfortunately… Yes they do return I've reset them several times with my handheld scanner, driven the car for readiness tests and then they have come back on
The secondary O2 sensor may be bad.
Check for a fuel cap leak. Also check whether the EVAP purge valve is disconnected. If not, test the power and ground wire for the valve.
pang_yeng
21
Nov 24, 2011 05:52 AM
