plz help me. 95 integra underdash fuse box c915 plug
Old May 3, 2015 | 01:45 PM
killaberna's Avatar
Default plz help me. 95 integra underdash fuse box c915 plug
Recently purchased a shell. Guy I bought the car from attempted to do a complete wire tuck. Now I'm finishing it and need help with a plug that goes to the back of the dash fush box underneath steering column.
Old May 3, 2015 | 01:47 PM
killaberna's Avatar
Default Re: plz help me. 95 integra underdash fuse box c915 plug
Old May 4, 2015 | 10:08 AM
killaberna's Avatar
BUMP! If anyone can find me a pic of the wires that go to this plug it will be much appreciated. Car is a 95 RS
Old May 4, 2015 | 12:20 PM
MotorMouth93's Avatar
10 Year Member
That plug connects to the rear wire harness as seen in the service manual screenshot you posted. That harness starts at the under-dash fusebox and then runs under the carpet between the driver seat and the driver door sill, so start by looking for cut wires under there. If you don't see anything there you'll need to go back further, which requires removing the interior plastic.
Since there are still stubs attached to the plug, it might be as simple as just finding the same colored wires in the rear harness and hooking them up.
Old May 4, 2015 | 04:55 PM
killaberna's Avatar
I found and re-attaced four of the five wires you see in the first picture because like you said I looked at the stubs and found the corresponding wires. After doing so I have two cut wires but one stub left that is so short their is no more colored wire only the cooper wiring. I ll try and get a picture of the two wires. Maybe someone knows which of the two it is.
Old May 4, 2015 | 05:04 PM
killaberna's Avatar
Old May 4, 2015 | 05:05 PM
killaberna's Avatar
Old May 4, 2015 | 05:06 PM
killaberna's Avatar
Is it the black one or the red one?? I'm thinking the red one because like you said its from the rear harness
Old May 4, 2015 | 09:06 PM
killaberna's Avatar
Bump
Old May 5, 2015 | 05:38 AM
EnjoyTheRideDC2's Avatar
How exactly are you reconnecting these wires back together? How do you have 2 cut wires with one stub left? And what are those last 2 pictures of? Those are pictures of 2 different sets of wires or what?
Old May 5, 2015 | 06:56 AM
killaberna's Avatar
I went to the junk yard and pulled a dash fuse plug and depinned it. This way I had wires that would go back into this plug in an OEM style. I then twisted the ends together and used heat wrap/shrink wrap to keep them secure. I dont know why I have two wires left and one stub. It makes me think i might be missing another stub. That's why I asked for a picture of the wires that go to the back of this specific plug. The last two pictures are of two different wires. One that runs from the back of the car (rear harness) and one thats coming from what seems to be the headlight harness. What's tripping me out is that the wires I reattached seemed to come from the same area as the wire that looks like its coming from the headlight harness. Maybe I need to look further and see if they double back to the rear harness and if in fact that wire that looks like its from the head light harness is or is it coming from the rear harness.
Old May 5, 2015 | 02:08 PM
killaberna's Avatar
Bump.
Old May 5, 2015 | 06:41 PM
killaberna's Avatar
Bump
Old May 5, 2015 | 07:04 PM
10 Year Member
Chill with the bumps...
I'd post a picture of mine but it's a 99' so has slightly different wiring and wouldn't really help anything. Start trying to trace the wires to the plug in the service manual, you should be able to find a PDF of it if you don't have it already.
Old May 6, 2015 | 06:58 AM
killaberna's Avatar
I have nothing better to do every few hours. Bump. lol just kidding. I work a daily 9-5 . I will do that this weekend. in the mean time. I'll continue to look through my pdf version of the service manual. I can't seem to find anything though!
Old May 28, 2015 | 06:54 AM
killaberna's Avatar
Turns out that the black wire that turns red in the first picture was just a wire feeding power to a tweeter. I finished up the tuck. If anyone finds themselves in this same situation my advice is to trace the wires back to its origin. Thanks for everyones help.
stevanrk
18
Nov 12, 2008 05:35 AM
DAP97SI
Oct 13, 2008 07:58 AM
ekay. jay
Apr 23, 2006 06:13 PM
hatch_dude
Nov 20, 2005 11:03 AM
litterbox
Jan 4, 2005 05:56 PM
