Help to identify
Old May 2, 2015 | 07:58 AM
KingSpade18's Avatar
Default Help to identify
can anyone help me figure out if this is a type r head?? It's mounted to a c5 block so I'm hoping it is
Old May 2, 2015 | 07:59 AM
Default Re: Help to identify
Old May 2, 2015 | 08:36 AM
1tuffbb6's Avatar
Can you get any pics of the head stampings? Should say PR3, also the dual valve springs are a tell tale sign as well.
Old May 2, 2015 | 08:44 AM
I couldn't really see whether the springs were dual or not because of the way they are angled
Old May 3, 2015 | 11:45 AM
IanBlake's Avatar
The PR-3 does not have anything to do
That PR3-X is just the casting stamp for the head. It ranges from PR3-1 to PR3-4. It could also be a B16 head.
Old May 3, 2015 | 04:13 PM
I'm aware of all that I'm hoping one of these pictures will help someone that knows more than me to identify this head, I've read and read and gotten as far as I can with it so a reply stating something I've read 100 times already is unnecessary.
Old May 3, 2015 | 08:43 PM
b18c5 power's Avatar
there's no way to tell 100% , if u want to know %100 u need to pull it apart !
Old May 3, 2015 | 08:46 PM
Then again it could be a b16 head with type r internal , or vide versa !
Ps u should change ur oil more often ....
Old May 3, 2015 | 08:50 PM
Then again ur in the wrong forum ....
Old May 4, 2015 | 09:07 PM
CW-ITR's Avatar
Reference to the third picture, I don't see the green paint near where the end of the fuel rail meets the distributor. Also, if all the internal parts are original, the bigger seats of the LMAs will indicate that this is an ITR head.
Old May 17, 2015 | 04:39 PM
4DRDB8GSR's Avatar
What is it date stamped, should be 97-01 with a PR3-X and then still very difficult to tell from a B16 SI head
Joe_the_diy_guy
Engine Machining & Assembly
Oct 22, 2016 10:04 AM
AdamB18C1EK
Feb 7, 2007 03:40 AM
ELAMINT5
Aug 3, 2004 08:35 AM
