Clutch Pedal Sensor
Old Apr 28, 2015 | 03:02 PM
DC4_Dad's Avatar
10 Year Member
Default Clutch Pedal Sensor
Hey guys,
So, today I was trying to adjust where my clutch pedal sits when released, and the treads on the adjuster snapped. So, I unplugged it and removed the thing all together. What's the purpose of this thing being plugged in? Could I just replace it with a bolt and call it a day?
Old Apr 28, 2015 | 03:37 PM
SpokaneSpeed's Avatar
Default Re: Clutch Pedal Sensor
It stops the car from starting without the clutch being depressed. You can jumper the connector with a paperclip or solder the wires together but just be aware if you're in gear and you don't push the clutch in, its going to try and start and will lurch forward.
Old Apr 28, 2015 | 05:12 PM
DC4_Dad's Avatar
10 Year Member
Oh, okay. This won't be an issue then. I had to replace the wiring harness in my last Integra (a whole nother story) and it was out of an automatic, so it would do the same thing if you didn't hold the clutch pedal in.
Old Apr 29, 2015 | 08:05 AM
MegP's Avatar
Bolt will work and you don't have to worry about soldering anything.
buustedEG
Mar 3, 2013 04:55 PM
Haarstad
Jun 24, 2012 09:50 PM
steronz
Sep 9, 2004 08:03 PM
Steve
Jul 23, 2001 01:42 PM
