B18b Turbo set up
Well im turboing my b18b1 in my 95 integra LS this summer. Its got 160,000 original KM's on it. Always run motul synthetic since I bought it about 3 years ago. All maintenance is always up to date. Burns a small amount of oil but what Honda doesn't... Heres my list. Pretty much using a greddy 18G kit. Im looking for around 250hp or so. So nothing to crazy. Any ideas/info would really help as im new to the turbo scene
Greddy TD-05 18G Turbo
greddy oil lines
greddy cast manifold
greddy intercooler & piping/hoses/ clamps
greddy blow off valve
440cc injectors
Tune wise I haven't decided yet...
I do have a exedy stage1 clutch to go in as well
greddy oil lines
440cc injectors
go search the Honda Tech website via Google in order to look at additions that are needed on the gritty kit to see that horse power level if you desire. The reason for this is, that in order to get over 250 wheel horsepower, you may need to have some adjustments in hardware.
everything else seems to look pretty solid for the purpose that you intend to use on your engine. Good luck to you
If all the photo links in my build thread from TeamIntegra were not broken I would link you lol. But I think you may want to ditch the oil lines that come with the kit and look into swapping the inernal wastegate for a better unit or adding a helper spring. The oil line is like a -6 or something, I would be afraid of over oiling.
Everything else, injectors, clutch, tune you're there. 250whp took 12lbs when I had it.
Ya I was thinking I might need some 440cc injectors as well a maybe a new fuel pump. The walbro 255?
As for horse power id be happy in the 220 range. Is the 18G a good turbo for the b1?
I was just going to do n/a oriented bolt ones but I can piece a turbo kit together for not much more
Is there anything else recommended that I change motor wise. Ive always kept up on maintenance (Tunes ups, oil changed, timing belt, etc etc)
18g isn't bad, it'll spool up pretty quick and be perfect for a low hp street setup. Personally whenever I boost an engine I upgrade to arp headstuds. I would also recommend upgrading to an adjustable fuel pressure regulator.
ARP's and a new head gasket I guess eh.
Or even a kit like this?
GoAUTO Integra Turbo Kit for 1994-2001 Acura Integra LS, GSR B18B, B18C | On Sale: $2,059.99
caspers_hatch
Nov 11, 2005 04:28 PM
