help with engine
I have a 94 Honda accord that just started vibrating and hesitating during 1st gear acceleration. Once you speed up it runs normal. also this morning when I started it it was smoking out the tail pipe until I started to drive and it stopped. What could be going on here?! CEL has never worked so can't get any codes
Black smoke indicates running rich. Which may mean coolant temp/O2 sensor issue. White smoke, is probably actually steam, which indicates coolant leak. Check your coolant, make sure you're not loosing level.
To replace the bulb, there's a few screws in front of the gauge bezel. Undue those, along with the plastic bezel. Cluster comes out
I only saw the smoke that one day. Starts up fine and after acceleration will run smoothly and fast. I'm a female so not really comfortable with taking the dash apart to fix the bulb.
On the 94-97 you have to remove;
And when you get to the gauge cluster, do not touch the fuel gauge/unbolt it. Only remove lexan and covers from the front. Do not unbolt/unscrew any gauges.
- Driver side knee guard(dash under steering wheel)
- Arm rest
- ash tray
- Center console radio surround
- Radio
- HVAC controls/surround
- And then the gauge cluster
Brandon H.
Jun 21, 2014 10:57 PM
joehonda1129
Nov 29, 2007 02:35 PM
finest_GSR
Jan 29, 2006 06:32 AM
