help with engine
Old Apr 24, 2015 | 02:39 PM
sneakerchic's Avatar
Default help with engine
I have a 94 Honda accord that just started vibrating and hesitating during 1st gear acceleration. Once you speed up it runs normal. also this morning when I started it it was smoking out the tail pipe until I started to drive and it stopped. What could be going on here?! CEL has never worked so can't get any codes
Old Apr 24, 2015 | 07:34 PM
holmesnmanny's Avatar
Default Re: help with engine
Start with getting the cel bulb replaced, which isn't really that hard at all. Then check for any codes.
Old Apr 25, 2015 | 12:03 AM
MAD_MIKE's Avatar
MM Gruppe B
What color was the smoke?
Does it smell like anything? Sweet would indicate coolant.
Old Apr 25, 2015 | 05:25 AM
I saw the smoke come pass the passenger window it was more like dark or black then white It only happened that morning and no more when I started it the rest of the day.
Don't you have to remove the dash for that?
Old Apr 25, 2015 | 06:37 AM
tim73's Avatar
Black smoke indicates running rich. Which may mean coolant temp/O2 sensor issue. White smoke, is probably actually steam, which indicates coolant leak. Check your coolant, make sure you're not loosing level.
To replace the bulb, there's a few screws in front of the gauge bezel. Undue those, along with the plastic bezel. Cluster comes out
Old Apr 25, 2015 | 06:30 PM
I only saw the smoke that one day. Starts up fine and after acceleration will run smoothly and fast. I'm a female so not really comfortable with taking the dash apart to fix the bulb.
Old Apr 26, 2015 | 11:04 AM
MAD_MIKE's Avatar
MM Gruppe B
On the 94-97 you have to remove;
  • Driver side knee guard(dash under steering wheel)
  • Arm rest
  • ash tray
  • Center console radio surround
  • Radio
  • HVAC controls/surround
  • And then the gauge cluster
And when you get to the gauge cluster, do not touch the fuel gauge/unbolt it. Only remove lexan and covers from the front. Do not unbolt/unscrew any gauges.
Old Apr 26, 2015 | 01:35 PM
NerfGunner420's Avatar
what happens if you remove the fuel gauge?
Brandon H.
Jun 21, 2014 10:57 PM
joehonda1129
Nov 29, 2007 02:35 PM
finest_GSR
Jan 29, 2006 06:32 AM
Tad
Feb 21, 2005 04:14 PM
