2000 gsr vss issues?
Old Apr 24, 2015 | 05:12 AM
vtackin's Avatar
Default 2000 gsr vss issues?
Hello fist time here hope someone could point me in the right direction. I was on my way home from work and near the end of my drive i take off in first and it hits a fuel cut at 4000 rpms (limp mode?) Then my cel came on. I got home turned it off for 15 mins went to run the code the ecu had reset it somehow. Went for a spin worked fine. Later that night same thing happens. The cel always goes away when I turn the car then back on, however the code does run when I stick the paperclip in the plug. I get 17 the vss but my spedo works just fine never had an issue. I have noticed my rpms hang a little when I start the car or it will idle like 2-3 hundred higher. I'm not really sure what's wrong. Could it be a bad ecu?
Old Apr 24, 2015 | 05:35 AM
vtackin's Avatar
Default Re: 2000 gsr vss issues?
Inside my p28. Could this be my issue?
Delsolbonez
12
Mar 12, 2013 03:24 AM
VtecFreePrelude
Engine Management and Tuning
Jun 27, 2010 11:26 PM
sinfulDB1
Mar 9, 2004 11:39 PM
oi-punx
Dec 14, 2002 10:00 AM
allmotor2000
May 11, 2002 09:12 PM
