Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
a/c blows warm
Old Apr 20, 2015 | 03:13 PM
ek.troy's Avatar
Default a/c blows warm
I have a 2007 si and I am having a problem with my a/c blowing warm after a while of use, its usually random but I'd say within 30 min of driving. I've checked my pressures and the low side is 45 and close to 200 on the high side while the a/c is working, haven't got a chance to check the pressures while its not working. I am thinking about evacing the a/c freon and recharge with new freon as I may have air in the system I also have 2 spare 12oz r134 laying around. Any opinions? thanks
Old Apr 21, 2015 | 05:19 AM
DaveSi677's Avatar
Default Re: a/c blows warm
I would check the freon first.
Have you check if the compressor is working correctly also?
Old Apr 25, 2015 | 05:48 PM
sytntyt's Avatar
Most common problem on these is bad compressor coil relay. Find the correct relay in the under hood fuse box And try applying pressure with your finger. See if the compressor cycles Off with it being pressed and cycles back on when you let off the relay.
Old Jun 14, 2015 | 06:38 AM
sstupid's Avatar
10 Year Member
When I had this issue, it was a bad air-mix motor.
beat
Apr 27, 2009 09:16 AM
311
Jun 17, 2006 09:25 AM
hanson said
Jan 14, 2006 10:20 PM
veggiemaster
Sep 28, 2004 08:56 PM
RebelleadeR
Mar 2, 2003 12:39 PM
