VTEC Wiring???
Old Nov 4, 2002 | 07:43 AM
lonefuzzy79's Avatar
Default VTEC Wiring???
I did a swap of a D16Z6 into a CX hatch but I am still getting the check engine light. A trip to the dealer's mechanic confirmed it is because the ECU isn't talking to the VTEC Solenoid. I need to wire the Solenoid into the harness properly, how would I do this, anyone know of a good schematic, or know how to do it themselves? Located in Bay Area, thanks
Old Nov 4, 2002 | 08:09 AM
DOHCtorTHRUST's Avatar
Default Re: VTEC Wiring??? (lonefuzzy79)
did you use the d16z6 harness?(SOHC vtec harness) if so everything is plug and play....it should be a peice of cake and there should be no CEL....
but if you use the CX harness you minus well yank it out because its a pain in the *** to wire up the o2 sensor.
Old Nov 4, 2002 | 08:33 AM
B_CRUZ!'s Avatar
I am assuming that you have a 95 CX and there for you would have to add the wire from A4 on the ECU to the shock tower harness. to find the right wire, you would need to get a Voltmeter. or you can do it the ghetto way and solder up a wire from the ecu all the way to the solenoid.
Old Nov 4, 2002 | 09:40 AM
Default Re: VTEC Wiring??? (B_Cruz)
bitchin thanks
Andyb22g
Mar 15, 2006 10:45 PM
MniMeHatch89
Feb 6, 2006 11:38 AM
Jmunk
Feb 6, 2005 08:28 AM
DB5000
Sep 6, 2002 08:48 AM
