Flickering oil light 92 Accord EX
Old Apr 10, 2015 | 04:39 PM
EscCtrl's Avatar
Default Flickering oil light 92 Accord EX
92 Accord EX.When I drive my car,the oil light flickers.I know it's about 1/2 quart low.I am planning to change the oil,but I'd like to know why the light flickers while I drive.When the car is still,it's off.I checked the wire to the oil pressure sending unit.All looks fine there.What else?Could it just be the low oil in combo with the hills around my area?Old oil?
Old Apr 10, 2015 | 07:16 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Flickering oil light 92 Accord EX
if the oil is too thin it may cause the oil light to flicker on.
However, these oil pressure switches are known to fail. They usually leak, and cause flickering. Usually cheaper/easier to replace the oil sensor and then see if the light still flickers, if so then it is time to do further diagnostics.
Old Apr 10, 2015 | 08:32 PM
EscCtrl's Avatar
Thanks for the info and the heads up.I'll change it when I change the oil later in the week.
Old Apr 15, 2015 | 07:09 AM
JamaicanAccord's Avatar
thanks mike i have the same issue...good info
Old Apr 15, 2015 | 09:34 AM
SpokaneSpeed's Avatar
Time to do an oil pressure test to confirm. ;-)
Old Apr 15, 2015 | 04:37 PM
Digitalis's Avatar
I wouldn't wait to test the oil pressure. If it's indeed the oil pump or bearings, ur d'icked. Better to find out sooner than later.
My 02 taurus spun a bearing with 140k miles after 4 months of me buying it used from a dealer
Old Apr 15, 2015 | 04:57 PM
^ exactly
Old Apr 15, 2015 | 06:13 PM
EscCtrl's Avatar
My car isn't being driven.It's a car I got a deal on from a family member.It will be a back up car.I'm doing some work on it,slowly, as I get the time and cash.I'm planning to install a real temp and oil pressure gauges.I have been let down before by inaccurate factory gauges.
Gtender23
Jun 2, 2013 12:44 PM
Jklango
Nov 13, 2012 05:00 PM
upsguy1969
Jun 22, 2011 12:55 PM
runderwo
Mar 29, 2007 10:39 AM
hillbillybob
Feb 9, 2005 07:05 AM
