Oil on underside of B18C1?
I have a fair amount of oil residue on underside of B18C1 and was hoping you could help identify issues.
The oil seems concentraded around the area between the block and transmission housing on bottom. In addition there seems to be oil around where the shift linkage enters the transmission.
Motor has 180,700. All original except mugen headers and skunk2 manifold
Ideas?
Ideas?
Ideas?
Ideas?
also make sure it's not just the Vtec solenoid gasket, that can be easily checked by opening the hood, on the left side of the block by the distributor super easy to replace if that is the case. Makes sure it's all clean in that area, oil could be leaking down from there.
rear main seal
oil pan gasket
Most likely both of these are causing the oil leaks, after all, it does have 180k miles and have suffered over a decade worth of heat cycles.
oil pan gasket
Ideas?
Ideas?
valve cover gasket for leaks,
distributor seal,
vtec solinoid,
worse case head gasket but you would have another thread asking why the engine isnt running right.
my guess distributor seal. It will leak and will collect in the shift linkage area as well as between the block and trans.
eghatch420
46
Apr 22, 2013 03:06 PM
superrally
Aug 25, 2003 05:24 PM
