2001 Accord Brake Line from Rear Wheel Cylinder
Old Apr 4, 2015 | 06:36 PM
Kanga's Avatar
Default 2001 Accord Brake Line from Rear Wheel Cylinder
I'm probably asking too much here but maybe someone will be generous with their knowledge....
So I cross threaded the hell out of the metal line going from the driver side rear cylinder to where it meets with the rubber line.
Since I haven't had any luck disconnected that metal line and rubber line (with some clip in between), it looks like I'll be replacing that whole foot and a half or so of line. Only problem is I don't have time to order the OEM parts and when I've checked Advance's stock of brake lines, it's just generic stuff and I'm not sure what I need.
Brake Line Schematic
It looks like the bent metal line is #12 and the rubber line is #3.
Can someone tell me what I would need to pick up from a local auto store to replace that?
Do I just need something like steel line and hose, in the right diameter plus some adapter?
Am I just being naive expecting a quick swap aftermarket line?
Thanks in advance to anyone who can help out.
Old Apr 4, 2015 | 09:17 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2001 Accord Brake Line from Rear Wheel Cylinder
Best would be to simply order/replace from Honda.
Size is most likely metric, measure the length of the steel piece and try and purchase a pre-flared piece that will only require you to bend it.
Old Apr 5, 2015 | 03:07 PM
Kanga's Avatar
Thanks for responding Mike.
I ended up getting the metal line and rubber hose off this morning once it was done leaking brake fluid and I could get a grip on it. Took it down to Napa and they found the replacements for me, just had to bend the new steel line.
BlitzSix
12
Jul 1, 2009 10:55 PM
shadycrx
Mar 11, 2006 09:27 PM
Deo
11
Dec 4, 2005 09:09 PM
AzntaggeR
Aug 17, 2003 07:50 PM
turbospool
Aug 10, 2003 11:38 AM
