PLEASE HELP! F22a6 Boost Tuning
Ok I have read and read and read and Im just stomped. Had a friend who was going to tune it but it just sat for 4 months so here I am back at square one. I need help with tuning this thing. My wideband reads at 14.x when i start it but as it warms up it just stays at 10.0 no matter what I change unless just hit the gas pedal. Then it fluctuates and goes back to 10.0. Im in desperate need of a base map, a lesson, something. I'm tuning on hondata s300. T3/T4 turbo, 1.2 turbo regrind cam, 650cc injector, F22a6, H23 IM. Can anyone help? I at least want to get it Idling fine, which its not bad where it is, and drive it NA. Just some kind of progress before boost.
Well, a bit of Google shows you a lot of results of forum threads, like this one:https://honda-tech.com/honda-prelude...e-map-2218853/
If you are not sure about you are doing with tuning, leave the job to a tuner. A bad tune would broke your engine
It's most likely an injector battery offset, if it's a tuning issue.
I would also check for physical malfunctions, like an injector stuck open, bad wiring, bad main relay, bad ecu or S300. Or perhaps a malfunctioning wideband.
...you are using a wideband right?
You can read the tuning manual in my signature. it's for crome, but since they're both rom editors, it's the same thing. Just a different layout.
