Crank no start problem. Integra b18b
Old Mar 30, 2015 | 05:00 PM
potatointegra01's Avatar
Default Crank no start problem. Integra b18b
I can hear the starter going off but it doesn't crank over. It has new spark plugs. I don't know if it's a coil or ?
The head was recently taken off I don't know if that has anything to do with it but all the wires are Intach.
Old Mar 30, 2015 | 05:44 PM
B_Swapped93's Avatar
Default Re: Crank no start problem. Integra b18b
confirm everything is plugged in and in the right order particularly your plug wires. next see which you are missing spark or fuel. Since you said the head has been off check the mechanical timing also.
Old Mar 30, 2015 | 09:27 PM
Everything seems to be in place. I am not getting any spark from the plugs
Old Apr 1, 2015 | 10:58 AM
tamboo's Avatar
10 Year Member
coil is the likely suspect but icm will bite the dust eventually too.
Starting Problems
Old Apr 1, 2015 | 09:32 PM
JBTuning's Avatar
H-T Platinum Sponsor
Please do a search. There are a lot of no start threads in this forum that will help.
Preludelearner
Mar 26, 2015 07:54 PM
j4s0n1337
41
Feb 19, 2011 07:50 PM
slacks
15
Oct 1, 2008 05:38 PM
killacam20
Jan 21, 2008 04:43 PM
