will 110 octane help....?
Old Nov 3, 2002 | 09:58 PM
H22A_pOwer's Avatar
Default will 110 octane help....?
i have a friend who goes to the drags every other week, and on that day, he'll be running less that a quarter on fuel. Then he'll add 2 gallons of 110. he said that will help him improve his q/t time... it that true? if it will help me get a lower q/t, i'll be running on 110 octane rather than 91
Old Nov 3, 2002 | 10:28 PM
PureTeg420's Avatar
Default Re: will 110 octane help....? (H22A_pOwer)
If he's not using some type of F/I, or 12.5:1 compression or higher he will NOT benefit at all from the higher octane
Old Nov 4, 2002 | 01:51 AM
jc836's Avatar
Default Re: will 110 octane help....? (PureTeg420)
WHo produces 110 octane unleaded fuel? You notice I said unleaded. Sunoco only goes to 100 for their race unleaded. Does it help-not really-unless you have cams and weird timing and an ECU that has been programmed. The sensors will detect the difference and adjust for it. I asked Sunoco Race Fuels about it and in simple terms the difference between 94 and 100 is when the fuel starts to burn.
Old Nov 4, 2002 | 04:34 AM
96LudeSiVTEC's Avatar
Default Re: will 110 octane help....? (jc836)
There is an Integra here in town that has just been built. On 91 octane he dynos somewhere around 350whp with 110 octane he dynos somewhere around 360-370whp. But he has an extreme build. He also told me that he has two programs that he runs, one for pump fuel and one for race fuel.
As for your car, I really don't think you would benefit any from higher octane fuel unless your experiencing detonation.
Old Nov 4, 2002 | 07:46 AM
H22A_pOwer's Avatar
Default Re: will 110 octane help....? (96LudeSiVTEC)
well yea....im going to stick with 91 octane, cause its $4.75 A GALLON!!!
Old Nov 4, 2002 | 08:12 AM
fastludeh22's Avatar
ya, higher octane is so you can run more timing/boost/n2o w/out detanation...your sig says 28 psi, but your times show a stock prelude times!!!?? also if you were just trying to make up #'s, rt is supposed to be .5xx not 5.xx... not saying you are just wondering
Old Nov 4, 2002 | 01:58 PM
714's Avatar
714
Default Re: will 110 octane help....? (fastludeh22)
I think he meant the air press. in his tires...
Old Nov 4, 2002 | 02:09 PM
armharm's Avatar
Default Re: will 110 octane help....? (714)
obviously... noooo he's boosting 28 psi and hitting 15's...
Old Nov 4, 2002 | 03:08 PM
714's Avatar
714
Default Re: will 110 octane help....? (armharm)
I was referring to fastludes comment
Old Nov 5, 2002 | 12:18 AM
H22A_pOwer's Avatar
lol...i wish i was boosting 28 psi!!! but then i wouldn't want to blow my engine! and yea i meant .571 not 5.71. mah fault
Old Nov 5, 2002 | 10:45 AM
skittlez's Avatar
Don't forget if you have a JDM motor its designed to take 100 octane...
Surprised the octane is so low over there - its 95-98 out the pumps here in the UK but then it does cost a more I think...
Judging by you lot all having massive bhps octane seems to make **** all difference anyway
Old Nov 5, 2002 | 12:22 PM
osuPrelude's Avatar
OH LORDY that's a lot. I thought it was a lot when prices hit $2.00 a gallon a couple years ago in Mich.
JDM KING
16
Jan 17, 2011 04:13 PM
rico892002
Jul 30, 2007 05:24 AM
Kutsuju_TurboCivic
Feb 10, 2005 03:39 AM
even91civic
Jul 19, 2004 12:47 PM
FifthGen
Oct 28, 2003 05:20 PM
