00 civic dx/y8 head-y7 block mini me --> o2 sensor question
Old Mar 27, 2015 | 06:24 PM
swizz977's Avatar
Default 00 civic dx/y8 head-y7 block mini me --> o2 sensor question
just finished my mini me y8 head on my y7 block its a 00 civic dx
i did everything by the book the only problem im having is with my o2 sensors for some reason my y7 sensors arent working at all..
im not getting any reading of voltage on my scan tool its just flat lined at 1.275
is there any differences in the y8 and y7 sensors?
i know the y8 upstream is opposite connector then the y7 harness o2 sensor
but the y8 cat downstream secondary one shares the same connection as the y7 harness o2 sensor and that is the only one thats actually giving me a reading now
everyone says theres no differneces but all the part numbers are different..
im just confused as to why my sensors arent working anymore
Old Mar 28, 2015 | 11:24 AM
HondaPartsHero's Avatar
Technical Hero
Default re: 00 civic dx/y8 head-y7 block mini me --> o2 sensor question
Do you have a code?
Old Mar 28, 2015 | 03:16 PM
swizz977's Avatar
well the code i got when my o2 sensor wasnt reading anything just flat line p0132 means high voltage for the primary ow sensor
Old Apr 2, 2015 | 05:23 PM
swizz977's Avatar
Default Re: 00 civic dx/y8 head-y7 block mini me --> o2 sensor question
i know there has to be someone whith some more info as to why my sensors arent working anymore
Old Apr 24, 2015 | 06:02 PM
swizz977's Avatar
ok i tried someone elses y7 o2 sensors and still got no reading from them which is wierd considering everyone tells me there the same
im using a y8 secondary for my primary o2 sensor which works and i swiched it in my secondary and i got reading there too so can anyone confirm that there y7 o2 sensors are working on there mini me while using the y7 harness??
Old Feb 5, 2018 | 01:26 AM
MolonLabe's Avatar
Did you ever find the problem to this issue?
benscivic22
Apr 5, 2015 05:11 PM
swizz977
Apr 3, 2015 07:45 PM
c1civic
Dec 27, 2006 03:27 PM
Cuong-nutz
Mar 11, 2005 10:13 PM
CroSi
Dec 9, 2003 10:50 AM
