B16b em1 engine problems :(
okay so i have a problem, my car starts fine idles fine revs fine but as soon as i go to drive it starts to like cut out like its turning on and off, its undriveable as it shakes so much when driving, what happened few days ago was driving just over took someone, then chugged and cel came on so i pulled over and revs were bouncing up down between 1000rpm and 2200 , so i drove home kinda just chugged a bit every now and then but was still driveable, now i cleaned iacv and the bouncing revs stopped , and now when i try to drive it wont
i have my fuel pump on a switch as wasnt priming ( relay everything works properly, but there is a wire botched into power at main relay ( onto yellow green power for fuel pump) and meets again on the same wire near door , i dont know why it was done maybe a break in wire? so i ran a wire straight from battery to fuel pump with switch and fuse myself and fuel pump works fine now, its just this problem now, i am running obd1 power r ecu , could the ecu be problem? or would be a sensor maybe map sensor? or maybe distributor? or 02 sensor? please help i need my car back thanks
i bridge the 2 pin connector?? no i didnt verify it just my buddy before had same problem he resoldered relay and fixed it, its a uprated ecu launch control shift light etc, it is a p30 obd1 ecu
boosteddohczc
10
Jun 11, 2009 09:57 PM
