Y7 Block swap Helppp!!!
Old Mar 26, 2015 | 11:51 AM
Justinrobi21's Avatar
Default Y7 Block swap Helppp!!!
I put a y7 block in my d16y8 civic. I have everything plugged up. I checked the alter to and fuel pump and that good stuff. When I try to turn on its not even wanting to turn over. No crank or anything. What could be my problem???
Old Mar 26, 2015 | 12:14 PM
slowDB7's Avatar
Default Re: Y7 Block swap Helppp!!!
so you completly replaced the y8 with a y7?
check the connections on the starter and battery.
How to all the grounds look?
Old Mar 26, 2015 | 12:20 PM
Everything is still the same on my d16y8 the only thing i swapped was the block from a y8 to a y7. BC I found the y7 cheap. I checked all my grounds.
Old Mar 26, 2015 | 02:09 PM
B_Swapped93's Avatar
ground or something is straight up not plugged in or not all the way. argue all you want that's the fact.
Old Mar 26, 2015 | 06:15 PM
slowDB7's Avatar
Double check battery clamp, you would be suprised how many times ive thought they were tight, and really were not
evanguy
10
Jun 1, 2011 06:35 AM
larry2009
Jul 8, 2009 10:06 PM
