Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 civic won't turn over
Old Mar 21, 2015 | 03:38 PM
jacobb89's Avatar
Default 04 civic won't turn over
My 04 civic lx auto transmission will not crank over. I replaced the starter and still nothing. It's getting full voltage from the wire that runs straight from battery to the starter, but the smaller black and white wire that tells it to crank is only getting 9.8 volts. Occasionally it will start if I turn the key a bunch of times. Any ideas? Thanks
Old Mar 21, 2015 | 05:51 PM
jacobb89's Avatar
Default Re: 04 civic won't turn over
Doing a little more probing I found that when the black and white wire is plugged in it gets no voltage when the key is fully turned, when I disconnect it from the solenoid it gets 9.8 volts. Same story at the ignition switch, nothing when connected to the solenoid, 9.8 when disconnected
530BB6
Jun 2, 2019 01:48 PM
cbaber
Mar 8, 2015 07:43 AM
happyabortion
Dec 10, 2012 05:11 PM
akouznet
May 29, 2009 11:12 PM
