94 civic cx a/c overcharge
Old Mar 21, 2015 | 04:29 AM
badcarma's Avatar
Default 94 civic cx a/c overcharge
greets gentlemen, here it is. believe my a/c sys is overcharged and causing drivability issues such as bogging missing vibration so forth with ac engaged with ac off smooth as silk.
I have done many searches and read the ac section of the service man and faq here and I see that below 30psi on low side is to low and below 150 psi on high side is to low indicating under pressure condition
BUT I cannot find out what the max psi is for low- high sides. maybe im blind but I cant find it anywhere.... anyone know? I really want to verify how overcharged the system is as concerned about damage to compressor due to overcharge. as a note when ac on compressor cycles and cycles and motor vibrates and jumps to the point of flexing the front motor mount thanks in advance
cap off: max psi on both low and high side of system what is top end spec
best regards dave
Old Mar 21, 2015 | 07:32 AM
Former User's Avatar
Default Re: 94 civic cx a/c overcharge
Depends on test conditions. Read through information posted in the recent thread below very carefully:
https://honda-tech.com/honda-civic-d...ystem-3242261/
Old Mar 21, 2015 | 07:35 AM
badcarma's Avatar
nobody? really? guys im not being lazy...and ive seen lots of folks have had the same issues. I just want to know what specs on low and high 134r capacity in psi not fluid ounces. even if the extra pressure is air in line what not . I need to know at what pressure it poses a risk to components tia
Old Mar 21, 2015 | 07:38 AM
badcarma's Avatar
thanks Ron! of all the guys on here you have always been most helpful. i'll read up
Old Mar 21, 2015 | 07:50 AM
badcarma's Avatar
I followed all those directions when charging. I used gauges under proper conditions to ascertain low 134a condition. I had a leak due to a bad leaking shrader valve which I replaced and brought system down to zero 134a. on recharge took 2 cans (12oz) to bring gauge and thermometer to system spec. blowing ice cold but on drive home severe rough running missing so forth. I feel I used an inferior gauge and hate to admit it but want it right....I didn't pull a vacuum on system. swaped the valve as fast as possible and proceeded to charge. I believe 134a is supposed to be 19 oz and 5 oz pag 46 oil that's all my info I guess I screwed the job by not pulling the vacuum . now I need to correct
Old Mar 21, 2015 | 07:54 AM
Could be air in system, due to known leak, and/or overcharged with refrigerant. Either way, recover refrigerant, replace receiver/dryer, pull deep vacuum and leak test, and then recharge by refrigerant weight, not high/low pressures.
Old Mar 23, 2015 | 07:31 PM
badcarma's Avatar
Ron, followed your directions and everything is perfect. thanks so much for the solid advice. I am lucky I didn't break the compressor as I used a quality gauge this time and my pressure was in the red before I discharged the system .....half way up so I lucked out. gonna keep an eye for leaks and the such for a few weeks but all in all I as stated purely lucky I didn't leak a hose or kill the compressor. again thank you sir!
best regards Dave
now I have to figure out why my rpm gauge needle moves to 1000 rpm when I put car ignition in start position with engine still not cranked...its always something
Old Mar 23, 2015 | 07:41 PM
Nice work!
arielb1
Jul 15, 2017 04:43 PM
Muckman
Jun 1, 2011 10:59 AM
Muckman
Aug 15, 2010 07:03 PM
2drEG
Jun 23, 2009 01:30 PM
