Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Trunk Vent Issue....
Old Mar 20, 2015 | 01:24 PM
mlee19841's Avatar
Default Trunk Vent Issue....
Hello all. Trying to see if you guys can give me some input.... I have a 02 white honda civic the coupe model. I replaced the trunk air vent since it was leaking... So today i look in the trunk and there is water again. I know its only that spot because i did the whole water test. When i pour water on the left rear side it goes over the fender and into the space between and goes into the top of the trunk air vent. I can physically see it leaking into the trunk from the top of the vent.. Im going to remove the bumper and put some rtv over the outside of the trunk vent also going to put some rtv between the spot of the fender also... What can i use to put over cover up the trunk vent from the outisde?? thanks guys/girls
Old Mar 20, 2015 | 01:30 PM
mlee19841's Avatar
Default Re: Trunk Vent Issue....
it also seems to be coming in from the darn flap opening. is there anything i can put over the outside of it when i take the bumper off. or some kind of foam sealant from home depot to put into and fill the whole flap opening up???
Old Mar 20, 2015 | 08:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There was a service bulletin regarding water leaks into the trunk from a body seam. Correction action would be to apply auto-body sealant such as 3M Ultra Pro Seam Sealer to the affected seam(s).
Honda TSB 03-067
Old Mar 21, 2015 | 05:42 PM
mlee19841's Avatar
thanks
Daniel Morgan
Aug 16, 2019 02:34 PM
OBDII Integra
Aug 27, 2008 09:11 AM
IVIcGurk
Jan 16, 2008 10:49 AM
joemeshuggah
Jan 16, 2005 10:44 AM
NiraCivicJDM
28
Jan 4, 2003 08:51 AM
