93 del sol si brake troubles
Old Mar 17, 2015 | 01:46 PM
Neth's Avatar
Default 93 del sol si brake troubles
So I went to leave this morning and my brakes felt funny, like they weren't engaging until very late on the pedal so I put it in park, turned the car off and pumped the brake and notice that the pedal was not getting harder to push. checked brake fluid and it wasn't low at all, I don't see any fluid on the ground by and of the wheels (4 wheel disc). Could this be caused by moisture in the fluid? The only thing I can think of is that while I was rebuilding the engine over months I had accidentally left the fluid cap slightly ajar. It's got just over 1000 miles on it since the rebuild, if that is the issue do I need to replace anything else, or just flush all the fluid?
Old Mar 17, 2015 | 04:51 PM
Former User's Avatar
Default Re: 93 del sol si brake troubles
Might be a bad master cylinder.
pedd240
Feb 3, 2024 11:15 AM
Nave43
46
Mar 26, 2015 03:01 PM
DelsolVted
11
May 7, 2011 11:33 AM
rawkus
Dec 19, 2004 09:59 PM
