95 honda civic 1.6L crank but no start
Old Mar 13, 2015 | 06:53 PM
Millerandrew's Avatar
Default 95 honda civic 1.6L crank but no start
I've done my distributor,timing,spark plugs,fuel lines filter and pump,new battery,compression test I'm at loss what am I missing? Please help?
Old Mar 13, 2015 | 06:55 PM
Former User's Avatar
Default Re: 95 honda civic 1.6L crank but no start
Test don't replace.
Fuel pump prime?
Bright white spark at all 4 plugs?
CEL codes?
Mechanical timing off by a tooth?
Old Mar 13, 2015 | 07:25 PM
What is the fuel.pump prime? And yes spark plugs all tested spark and timing is on
Old Mar 13, 2015 | 07:28 PM
Turn key from off to ON(II) and then listen for whether the fuel pump runs (buzzing noise below rear seats) for 2 seconds and then turns off. Also watch whether the CEL turns on and off after 2 seconds.
Is spark bright white at all 4 plugs?
and timing is on
How do you know?
Old Mar 13, 2015 | 07:46 PM
I've done timing before its backfiring so.it shouldn't backfire if it was the timing And yes all 4 sparks bright white and no cel codes
Old Mar 13, 2015 | 07:52 PM
What?
^Do this and report back.
Old Mar 13, 2015 | 08:13 PM
Fuel pump is fine and no cel codes
Old Mar 13, 2015 | 08:24 PM
I'll give your thread one last chance. Did you do the test and hear the pump prime?
Old Mar 13, 2015 | 08:28 PM
Yes the buzzing sound when you turn the key over once before you try and crank it it was making the buzzing sound and I checked my fuel injectors and its getting fuel. Is there anyway that if fuel is in the oil that could make it not start?
Old Mar 13, 2015 | 08:31 PM
Good. Did the CEL turn on and then off after 2 seconds?
What are the compression numbers for the 4 cylinders?
Have you actually checked the mechanical timing?
Old Mar 13, 2015 | 08:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This thought of yours is very incorrect. It will be way more likely to backfire if your mechanical timing is off.
FYI, this statement of Ron's is a subtle warning that he is near walking away from your issue:
So here is a word to the wise:
Failure to follow his directions precisely and/or report back in detail what you did to follow his directions will prevent you from receiving his expert advise and you will likely be stuck on your own to get this dialed in and working properly. Quite often the secret is in the details so omitting them makes life impossible for all involved.
I'll now return you to the very prolific RonJ as he is being extra patient with you and running you through the proper diagnostic procedures. If you follow his advise concisely and report back in detail how you followed his exact steps, you will have a running car shortly or know specifically what is wrong and needs repair.
Best of luck.
Old Mar 16, 2015 | 12:37 AM
okadaman's Avatar
Hey did you check inertia switch?
It is behind the glove compartment on the left, at least on 6gen.
MintyCivic
Mar 6, 2016 03:52 PM
infinkc
Feb 21, 2013 01:32 PM
purgat0ry
Sep 7, 2012 02:38 PM
Speardog
Jul 24, 2010 08:20 PM
R_type
Jun 1, 2005 01:48 PM
