2000 Honda civic running rough
Old Mar 13, 2015 | 05:26 AM
Aadavis94's Avatar
Default 2000 Honda civic running rough
Hello I just did a spark plug and wire change on my 2000 Honda civic ex. Now it is running rough. Any ideas why?
Old Mar 13, 2015 | 05:55 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: 2000 Honda civic running rough
What kind of plugs did you put in?
Old Mar 13, 2015 | 05:57 AM
Aadavis94's Avatar
NGK platinum.
Old Mar 13, 2015 | 06:02 AM
09chaplak's Avatar
Loves Tossing Salad
I'll assume the wires are the same. I guess we'll start from the top. CEL on? Did you move the distributor at all when changing out the wires? Check your timing just to be sure. Clean you IACV. All this stuff can be found in the FAQ section, https://honda-tech.com/honda-civic-d...tions-1998336/
Old Mar 16, 2015 | 04:22 PM
Aadavis94's Avatar
Can someone please tag the thread or on how to clean your IACV. or send me picture and steps please.
Old Mar 16, 2015 | 05:51 PM
redm3turbo's Avatar
welcome to honda-tech.
Your not going to find much help asking questions like these
People make DIY's for things like this---
search "clean IACV"
you look at the pictures and steps--
on a side note---did you make sure you connected the plug wire to the correct location on the dist cap?
Id try pushing them on again and make sure they all seated properly on the plugs.
Did you do anything else? or Just plugs/wires
Old Mar 17, 2015 | 01:07 PM
tony_2018's Avatar
Fish Twig
You probably mixed up the firing order of the plugs... thats the only thing I can think of.
Old Mar 17, 2015 | 01:35 PM
Jimi Hondrix's Avatar
Agree
Old Mar 18, 2015 | 05:39 AM
antrmo's Avatar
Icon6 Re: 2000 Honda civic running rough
guessing the issue was fixed?
Old Mar 18, 2015 | 05:43 AM
Aadavis94's Avatar
Sorry guys. Been busy. I replaced the pcv valve. (Honda put it in a really inconvenient place for some reason). It was the original one form 15 years ago. Pretty bad. Now the idle is fluxuates at idle. I'm going to take the IAC valve off (finally found it yesterday) today and clean it up to see if that helps.
Old Mar 18, 2015 | 05:52 AM
antrmo's Avatar
all good stuff to do.but didnt this all start after just changing the plugs and wires?
Old Mar 18, 2015 | 05:57 AM
Aadavis94's Avatar
Yes it did. But I think I had just noticed how tough it really was after I had changed the plugs. They were once again the original ones from 15 years ago. I had just got this Honda and the previous owner had not taken care of it very well.
Old Mar 18, 2015 | 06:21 AM
antrmo's Avatar
ok,just thought it was bad after you did the "tune up"
Old Mar 18, 2015 | 06:26 AM
Aadavis94's Avatar
Sorry. I misspoke (mistyped?). I meant to say it was still running rough after the tune up
Old Mar 18, 2015 | 08:05 PM
antrmo's Avatar
any luck?
Old Mar 18, 2015 | 08:35 PM
Aadavis94's Avatar
Yes. After I cleaned the iac valve it runs much better. It was really gunked up. Next I'm gonna clean the throttle body. I was going to do it today. But getting to my iac valve is not fun
Old Mar 18, 2015 | 08:40 PM
Former User's Avatar
It's easier to just remove the entire throttle body, assuming you have an auto trans or D6Y7 engine.
Old Mar 18, 2015 | 08:59 PM
Aadavis94's Avatar
I have an auto trans but the D16Y8
Old Mar 18, 2015 | 09:02 PM
All auto trans have the IACV attached to the TB. It's easier to just remove the TB to clean the IACV, and may as well clean the TB while you're at it. A replacement TB gasket only costs $2.
Old Mar 18, 2015 | 09:08 PM
Aadavis94's Avatar
Anything I should know before I take the TB off. Any hints or tips?
Old Mar 18, 2015 | 09:09 PM
You need a torque wrench to reinstall the nuts and bolts.
Drain the coolant to avoid making a mess.
Old Mar 19, 2015 | 07:31 AM
Aadavis94's Avatar
How tight do they need to be?
Old Mar 19, 2015 | 07:47 AM
See diagram.
dave.s3693
Jan 8, 2023 11:29 AM
tepasoelrolo
14
Oct 16, 2019 08:17 PM
UpinOregon
Dec 2, 2011 07:04 AM
duffcore
Mar 6, 2010 02:50 PM
ewtester
Apr 17, 2005 10:30 PM
