d16a6 in a eg hatch no start
Old Mar 8, 2015 | 03:13 PM
gsr_b20b's Avatar
Default d16a6 in a eg hatch no start
Hey guys so I just finished up swapping a recently rebuilt d16a6 into a 1993 dx hatch. When I bought the motor it had no cam gear on the motor so I used the d15b2 one off the old motor. Then used a d15b2 timing belt. Set the timing and put the motor in the car. Now it won't start. Turns over but sounds like there is no compression. Pulled the plugs out to do a compression test and the plugs are soaked in fuel. There for it is getting fuel forsure and I also checked for spark.
Upon testing for compression all 4 cylinders show no compression at all. But could this be from fuel washed cylinders? Tested the compression tester on a different car to rule out if its the compression tester but it worked fine. Could the plugs be fouled? They are soaked in fuel. And is there differences between a d15b2 and d16a6 timing belt and cam gear? Any help or input is appreciated
Old Mar 8, 2015 | 03:17 PM
Oaken81's Avatar
Default Re: d16a6 in a eg hatch no start
Did you check the mechanical timing of the engine?
Old Mar 8, 2015 | 03:24 PM
gsr_b20b's Avatar
Yes it's dead on
Old Mar 8, 2015 | 05:09 PM
Former User's Avatar
Unplug the fuel injector clips. Add teaspoon of oil to each cylinder, and redo compression test.
Old Mar 8, 2015 | 05:17 PM
HondaPartsHero's Avatar
Technical Hero
Also what injectors and distributor are you using? ECU as well?
Old Mar 8, 2015 | 05:22 PM
B20VtecVillain's Avatar
Have you checked to see if your getting spark? If you are not even with new/clean plugs then definately look into what's going on with your dizzy, ecu, IGN, wires etc. If your getting spark and fuel, and the results of a no fuel compression test still show very low comp, it would then be that whoever did the the recent rebuilding on that a6 was not up to par.
Old Mar 8, 2015 | 05:32 PM
neownd sxt's Avatar
^^ sounds about right. Did you by chance do a compression test before you bought the motor or just after? Also do you know who put the rebuild together?
Old Mar 9, 2015 | 08:59 AM
gsr_b20b's Avatar
i didnt do a compression test before i boguht it. but i bought it and it sat for a few months. could the base timing be 180 degrees out?
Old Mar 9, 2015 | 09:01 AM
gsr_b20b's Avatar
before i bought the motor i saw it running in my friends car, which he wrote off then parted out. could it also be valve lash? because i bought the motor with no cam and no cam gear, i got another d16a6 cam shaft from the autowrecker and put it in. could the adjustment be so far out that the valves are staying opened?
Old Mar 9, 2015 | 09:20 AM
If the static timing was ok you would have compression regardless of what was going on with the dist. And such.
Old Mar 9, 2015 | 10:02 AM
gsr_b20b's Avatar
So could it be valve lash to create no compression or is it likely that it has bent valves
Old Mar 9, 2015 | 10:04 AM
Old Mar 9, 2015 | 10:09 AM
gsr_b20b's Avatar
Okay I'll try that Ron
Old Mar 10, 2015 | 09:33 PM
gsr_b20b's Avatar
So after trying with oil in each cylinder I could not regain compression. So just thought I would check the valve adjustment. Found my problem, the valves were actually staying slightly opened at all times. Set the valve adjustment with a feeler guage to specs, did a compression test and bam 170psi across the board. Threw some new spark plugs in, smoked out my neighborhood when it finally started (had to burn out the oil and wd40 I put in the cylinders ) and now it runs amazingly.
HondaMike2112
26
Jul 7, 2019 01:16 PM
NavsENG
11
Mar 11, 2013 03:55 AM
vtechaccord
Mar 13, 2011 08:21 PM
J-Brooks
Mar 9, 2006 06:31 PM
