HELP!!! FIRST TIME EGR PORT CLEANING.
Old Mar 7, 2015 | 04:14 PM
jarthe3's Avatar
Default HELP!!! FIRST TIME EGR PORT CLEANING.
Hi I'm cleaning my egr ports on my car. 94 Honda accord DX and I was wondering how easy and eta time to complete. This is my first time doing anything like this. Any help would be appreciated
Old Mar 7, 2015 | 07:26 PM
19Accord97's Avatar
Default Re: HELP!!! FIRST TIME EGR PORT CLEANING.
I did mine a couple years ago and it really isn't very hard at all.
I'd say for you it might take an hour or two. Just be sure when you remove the fuel rail that fuel will leak out (not much) but be sure to clean it up and avoid any flames. Follow the DIY that is in the sticky section and you'll be just fine.
Old Mar 7, 2015 | 08:32 PM
jarthe3's Avatar
Did you notice any performance difference's or did it pretty much run the same?
Old Mar 7, 2015 | 08:49 PM
holmesnmanny's Avatar
On your car it will be a cinch compared to most other hondas.
Old Mar 8, 2015 | 07:48 AM
jarthe3's Avatar
What's the difference between mine compared to most Honda's
Old Mar 8, 2015 | 09:27 AM
Lost Again's Avatar
The 5th gen have a nice little "plate" you remove.......4th gen have "plugs" on the intake (six I think) that have to be pulled out with a slide hammer or some other type of puller. The six gen 4 cyl you have to remove the upper part of the plenum....the 6 cyl's aren't that bad but to "do it right" the intake has to come off.
So compared to the 4th and 6th gen 4 cyl's Accords....yea the 5th is easier, IMHO.
Back to the topic......why are you doing this, are you having an issue or just because?
Next is the decision to pull the rail off the injectors or pull the rail with the injectors. Either way, the upper and lower seals are ~21 years old. So decide which way you are going to pull the fuel rail - then IMHO get new seals for the injectors (upper or lower).
Old Mar 9, 2015 | 02:02 PM
19Accord97's Avatar
Not much, but only two of them were slightly clogged.
Old Mar 9, 2015 | 05:38 PM
masospaghetti's Avatar
That inspection plate will make it much easier. On my 93, I had to use a slide hammer and screw attachment to pull the plugs out. The hardest part is trying not to drill all the way through the plugs, metal shavings down the intake is usually considered a bad thing. (I used chassis grease on the drill bit to catch the shavings, because I did end up drilling through one of the plugs).
As far as performance, it might help with some drivability (light throttle, idle, and throttle transitions). WOT performance probably won't change since the EGR should be closed during WOT anyway. But I found an excessive amount of carbon in mine, I suppose yours will be similar, two of the ports were completely clogged, two were restricted.
Old Mar 10, 2015 | 06:25 AM
katinhat's Avatar
Just did this on my 2001 (different than yours, mine has a single tube cast into the manifold that runs from intake plenum to the EGR valve), and it made a big difference under moderate throttle. Had been shuddering, seems much more responsive now plus the hesitating is gone. I bench tested the sensor by clamping a couple of wires to my battery and touching on the appropriate pins, worked just fine so saved the $112 for a new one. Just cleaned up the bottom portion of it and reinstalled with new gasket. (Could probably have used the old one, but had already bought a new one so threw it on.) You might see if Eric the Car Guy's video on it is your engine, I thought it was a mid-90's, it was definitely earlier than my 2001.
Old Mar 11, 2015 | 07:39 AM
jarthe3's Avatar
I've been having a random cel that pops up very randomly and not for a long time either some times once a day sometimes every 2-3 and its only stays on for 15-20 mins then goes away or whenever I restart my car. I took it to the Honda dealership to get codes pulled but unless my light stays on the code isn't staying logged so that can't say for sure what it is bit the tech said it's most likely my ports need to be Cleaned or my o2 sensor but he did a visual inspection and said it looks in good shape plus it was replaced like just over 3 yes ago so he said its probably my egr ports.
Old Mar 11, 2015 | 07:41 AM
jarthe3's Avatar
Thanks I'll deff look that up
Old Mar 11, 2015 | 05:07 PM
Lost Again's Avatar
Stop, I call BS on what you are being "told". The codes will store/stay in memory until power is removed from the ecu.
So I don't buy what you are being told. There is more to this story AND DO NOT SPEND A PENNY on any suggested "repair/fix" until you have better information.
Old Mar 11, 2015 | 05:10 PM
Lost Again's Avatar
PS - a 94/95 Accord will not set a code for clogged egr ports - it is OBD-I, meaning the "flow" is not checked on these.
Old Mar 11, 2015 | 05:19 PM
jarthe3's Avatar
actually they didn't have many get anything repair thanks hold me to go ahead and wait until it's a solid and they can try to figure it out but he said his personal experience that's what it was one of those two things that he has he seen it before
Old Mar 11, 2015 | 05:20 PM
MAD_MIKE's Avatar
MM Gruppe B
If the code is not being stored then the ECM memory fuse 7.5A is probably blown.
Check the underhood fuse box.
98-02 F23s have a single port that requires the upper plenum to be removed to clear the EGR port.
94-97 F22s have an EGR manifold that can be removed and cleaned, along with individual runner ports.
90-93 F22s have individual plugs and ports that need to be removed and cleaned, best way to deal with that is to shoot yourself.
Old Mar 11, 2015 | 05:23 PM
MAD_MIKE's Avatar
MM Gruppe B
It will not becomes solid, even if it does when they try to retrieve the code it will not be stored in the ECM as the memory self cleared when the car was turned to off.
No memory fuse, no memory, no code will be saved/stored for later retrieval.
Old Mar 11, 2015 | 06:58 PM
Ya when the check engine light comes on you need to safely pull over and without turning off the car, pull the code(s).
Old Mar 11, 2015 | 07:25 PM
jarthe3's Avatar
how do I pull the codes is there a machine I can buy if so how much does that cost
Old Mar 11, 2015 | 07:39 PM
MAD_MIKE's Avatar
MM Gruppe B
On 94-97 look under the glovebox door.
You will see two blue connectors, unlock and pull the two wire connector down.
With a wire/paper clip jam it into the end of the blue two wire connector.
Watch the CEL and D4 lights for blinking. Long blinks are tens, short blinks are ones, thus if the CEL or D4 lamp blinks ' _(slight pause)-----' That would be a code 15. The codes will repeat, so keep watching until you are sure you have seen the same code(s) repeat, then you know you have seen all the codes,
Write them down. Come back here and post.
Old Mar 11, 2015 | 09:20 PM
jarthe3's Avatar
Sounds a bit complicated but I will give it my best shot. Also does my CEL have to be on when I do this
Old Mar 12, 2015 | 01:13 AM
MAD_MIKE's Avatar
MM Gruppe B
Sounds a bit complicated ...
No. Your CEL lamp needs to be working to retrieve codes on OBDI cars to retrieve codes, yes.
Your CEL does not need to be on all the time(hard fault) to retrieve codes.
It is a good idea from time to time to check for stored codes to verify that your vehicle is in optimum condition.
Old Mar 12, 2015 | 08:28 AM
jarthe3's Avatar
Awesome will do is there a OBDI reader I can buy that isn't expensive. I know I went to like auto zone but all the car parts store don't anything older than 1998 cars
Old Mar 12, 2015 | 02:23 PM
MAD_MIKE's Avatar
MM Gruppe B
There are no code readers for pre'96 Hondas.
You use a paperclip and short out the blue two wire connector located under the glovebox door.
Laceyfer
Jul 17, 2009 02:50 PM
michichu
Nov 1, 2007 06:13 PM
lost_identity_82
Sep 24, 2004 05:38 PM
civicracer1993
Sep 19, 2002 04:59 PM
91BlackAccord
May 13, 2002 01:07 PM
