Passenger side lock is jammed.
Old Mar 6, 2015 | 11:17 PM
Jamie Kitchens's Avatar
Default Passenger side lock is jammed.
When I unlock or lock the outside lock slot on the driver's side, the lock will engage or disengage. However, the passenger's side one will not move. Any suggestions?
Old Mar 8, 2015 | 12:55 AM
Lost Again's Avatar
Default Re: Passenger side lock is jammed.
Can you manually unlok the door?
You can test the lock actuator. For any more information - we are going to have to know what the year, trim and number of doors.
Old Mar 8, 2015 | 12:17 PM
I can manually unlock the door, inside or outside with the key. It's just that the driver's side lock, when unlocked does not unlock both doors. It used to do that. I have a 2001 Honda Accord Ex Coupe.
Old Mar 8, 2015 | 02:13 PM
rockycat's Avatar
Gotta hit unlock on drivers side twice to unlock passenger side.
Old Mar 8, 2015 | 03:13 PM
rockycat, the problem I am having is a new one. When I first got the car, unlocking the driver's side lock would unlock both doors with one turn.
Old Mar 8, 2015 | 03:47 PM
rockycat's Avatar
Just checked mine and it is not a two turn process but it is a long hold for the other doors to nunlock.
Old Mar 8, 2015 | 04:38 PM
Not a single combination of factors works. None that I have tried, nor any recommended on this thread. I give up. I suppose there is a mechanical issue somewhere, but it is not worth pursuing in my opinion. Thanks.
Old Mar 9, 2015 | 05:37 AM
Fitz Williams's Avatar
10 Year Member
The problem sounds electrical, not mechanical.
Old Mar 9, 2015 | 01:56 PM
The problem is not serious enough to worth pursuing, thanks.
mystikalcaramel
Mar 23, 2019 01:19 PM
viper111
Jan 10, 2013 09:59 AM
cd5lover
Mar 13, 2012 08:31 PM
jessa024
Jul 14, 2011 03:02 PM
HondaVtec139
Jul 7, 2002 12:05 PM
