Squeaking noise when clutch engaged
Old Mar 5, 2015 | 06:10 PM
TYBG's Avatar
Default Squeaking noise when clutch engaged
Hi all, I have a 95 Civic LX with 112,000 miles on it. Just got it two months ago, and have replaced the head gasket, timing belt, water pump, and thermostat on it all in that time. Naturally, another problem has come along. On most start ups, theres a squeaking noise, no matter if its cold or not. Occasionally whenever I upshift or just have the clutch engaged, the squeaking noise happens again. The car usually has a hard time getting into first and reverse, and today it made a grinding noise getting into second two or three times. The noise has been going on for about two weeks now, any idea if its anything bad or what it could be?
Old Mar 5, 2015 | 06:48 PM
White_EG1's Avatar
Default Re: Squeaking noise when clutch engaged
Originally Posted by TYBG
Hi On most start ups, theres a squeaking noise, no matter if its cold or not. Occasionally whenever I upshift or just have the clutch engaged, the squeaking noise happens again.
With the clutch pressed in is the squeak still apparent? Please be more descriptive.
Squeaking on start up could be anything, how do you know its coming from the tranny?
Old Mar 5, 2015 | 06:51 PM
TYBG's Avatar
Yup, squeaking noise is only there when clutch pedal is pushed down. It sounds like the same noise, so Im assuming that it has something to do with the clutch/transmission. Happens in gear and in neutral.
Old Mar 5, 2015 | 07:10 PM
JarvisW's Avatar
Sol to Sol
Was the clutch ever changed?
Used to have the throwout bearing squeak in my VW Bugs when they were toast...
Old Mar 5, 2015 | 07:14 PM
TYBG's Avatar
I dont believe so, but Im not 100% sure.
Old Mar 5, 2015 | 07:45 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
I have a squeak too ... but it's the bushing on the clutch pedal. Your sound is coming from where?
Old Mar 5, 2015 | 07:51 PM
White_EG1's Avatar
That means when the clutch is disengaged, not engaged.
I personally have the same noise but goes away, when clutch is pressed. I'd start with flushing the tranny fluid. But it's most likely your throw out bearing.
EDIT: pinpoint where the noise is coming from, It can be from the pedal itself try lubing up where it connects threw the firewall or in my case slave cylinder which would need to be replaced.
Old Mar 5, 2015 | 07:57 PM
White_EG1's Avatar
Originally Posted by deschlong
I Your sound is coming from where?
Thought I was the only one having a hard time interrupting his posts lol.
Old Mar 5, 2015 | 08:39 PM
chrysler kid's Avatar
Throw out bearing is making noise. Mine only does it when it is very hot outside
Old Mar 5, 2015 | 11:10 PM
ReMiXeDg's Avatar
My 98 lx does the same thing it sounds a bit like a wet belt can this be the throw out bearing? What happens when it gives up.
AussieR
Sep 4, 2016 08:30 AM
UpAndComin
Transmission & Drivetrain
Feb 17, 2009 08:25 AM
TegraD
Sep 20, 2008 10:24 PM
mrmonk
Apr 1, 2004 03:32 AM
