Pulling CEL codes on b16a2 P30ecu?
Old Mar 3, 2015 | 04:07 PM
92hatchciv's Avatar
Default Pulling CEL codes on b16a2 P30ecu?
I tried to pull the CEL codes in my 92 civic that has a b16a2 and p30 ecu, but I never got any flashing light at all. I tried it a few times and nothing. The CEL just stays on! Any tips? I tried searching, but didn't find much.
Old Mar 4, 2015 | 03:46 PM
92hatchciv's Avatar
Default Re: Pulling CEL codes on b16a2 P30ecu?
Should I try to reset the ecu or does this mean the ecu is bad?
Old Mar 4, 2015 | 03:58 PM
NotARaCist's Avatar
I never narc'd on nobody!
Exactly how are you trying to pull codes? Are you sure you aren't messing it up? After the guy who wanted to ground out harness wires the other week...
Old Mar 4, 2015 | 04:02 PM
92hatchciv's Avatar
Paper clip, and I tried it a few different times while watching a video just to make sure.. I don't know what I could be doing wrong, but I also have never done it before either lol
Old Mar 4, 2015 | 04:09 PM
NotARaCist's Avatar
Take a picture of where you're sticking the paperclip.
It might seem silly, but I'm serious when I say a guy wanted to pull a wire out of his ECU to ground it to check for codes, because his dumbfuck "mechanic" told him to. Covering all the bases before we tell you your ECU is fried.
Old Mar 4, 2015 | 04:18 PM
92hatchciv's Avatar
Well, here it is.
Old Mar 4, 2015 | 04:24 PM
NotARaCist's Avatar
Are you sure you're getting them in there deep enough to make good contact? If you are, then reset the ECU, see if the CEL comes back on, and try to jumper it again. If it still stays solid, then hopefully you have a friend with a working P30 (A P28 can work for a quick test, but shouldn't be used long term) to test.
Old Mar 4, 2015 | 04:27 PM
92hatchciv's Avatar
That's what I thought at first, but I pushed them in there pretty good. Should I try and shove the in there? I'll try to reset it and try it again.
Old Mar 4, 2015 | 04:29 PM
NotARaCist's Avatar
Yeah, I mean, worst case you pop them out of the plug...and they're easy enough to pop back in.
Old Mar 6, 2015 | 07:47 PM
Another_Si_Guy's Avatar
I know EricTheCarGuy on YouTube uses a female connector to attach to the male one on your car. It may seem like a hassle now, but it may come in handy in the future.
rick_rabies
Engine Management and Tuning
Aug 24, 2009 06:22 PM
jpar195
Apr 7, 2008 12:01 PM
h8tred
Jul 7, 2003 08:35 PM
