10 codes & stuck in 2 gear
Just got my wife a 98 accord j30a1 ran good but two days ago while i was at work my son drove it ( says didnt run to hell ) well now it seems to b stuck in second & if i cut key off and restart it will go in rev. It kinda slips on and out codes 1-2, 7, 7-1, 7-2, 7-3, 7-4, 7-5, 7-6, 8 WTF I do most all my mechanic work and i dont know where to even start HELP
Last edited by prelude h22a4; Mar 2, 2015 at 08:36 AM. Reason: didnt put model of car
12- EGR lift insufficient/voltage output high
7- TPS Voltage High/Low
71-76- Random misfire on Cylinders 1-6(this would be caused by insufficient EGR lift, a lean misfire)
8- Top Dead Center sensor malfunction, intermittent or no signal.
Proper OBDII codes would greatly help out.
I would suspect a ground may have come loose or broken. Check the engine wire harness for any damage, check the grounds are all intact, clean and tight.
These odb2 codes p0401, p0420, p0730, p1399, p1491, p1498, p1705, p1739 . Got these codes from autozone he mentiond the misfire codes to but didnt write those down
P0401- Exhaust gas recirculation(EGR) Insufficient flow
Most likely a blocked EGR port.
P0420- Catalyst system efficiency below threshold.
If the emissions system(EGR) is faulty this will cause this code. Ignore this until all other engine codes are fixed.
P0730-Shift Control system
Hydraulic side of transmission.
P1399- no code. Are you sure it wasnt P1359(8)? Crankshaft Position(CKP)/Top Dead Center(TDC) Sensor Circuit Malfunction.
P1491- EGR valve, insufficient lift.
P1498- EGR Valve position sensor circuit high voltage.
P1705- Transmission Range Switch short to ground.
P1739-3rd Clutch Pressure Switch
Check the passenger side footwell for any damage to the floor, pull the carpet back and see if the wire harness going to the PCM is damaged/water logged/etc. Ask your son if he went through a large puddle or snow drift.
2nd gear is default limp mode when there are multiple problems.
Thanks Mike il check that out im morn. A man has had a rough week lost my job due to snow and not being able to make it there anyway . Seems like every time my son gets in a car it gets fucked up again Thanks man il check that out
Mea cupla, P1399 is the the temporary code(which causes the flashing) for misfire the stored code is usually P0300-P030* depending on which cylinder is misfiring.
So you can place the shifter into R with no problems, but the transmission does not engage reverse? What happens if you leave the engine running, shift down to D1 and then back up to R? Does the transmission still not engage?
On the 98-02 ATs Reverse does need the shift solenoids to actuate to work, P1705 may be the reason it is not working.
Have you checked the transmission range sensor/switch on the side of the case? Is it damaged? Is the wire harness damaged?
The only way to get in rev is after you first start car once u move gear shifter in to d,1,2,3 you have to cut car off and restart. Going foward it has 1st & 2n. After you have went foward fast enough to switch to 2nd then when u stop it will go back to first but its like u have to slip it out of 2nd by hitting gas car will move then the rpm goes up when outbof gear then when rpm comes down a lil then it will slam into 1st. Thanks for any help in addvance i know d b h k series pretty well in and out but im a virgin anything j series
I drove car yday and still wont shift to d3 or 4 will start in 1s then run in limp mode 2nd will slip out of gear and rev up then BAM your back in gear. I think something bad is wrong guy. Theres a nice rebuild FAQ that is starting to look like good option im in east tenn bty
Il get back to you on that after lunch today almost 8 am now. After i clean all the engine grounds & tested gps yday i put back together and tried to drive and it untill it got warm went through all the gears but after heated up to opp temp back to 2nd. It dosent pull now either more like a d15 power. Found metal in atf man gave up and chalked up to rebuild. I will reset and run again like you asked me to in a bit. Thanks
Originally Posted by prelude h22a4
Originally Posted by MAD_MIKE
If you are using a phone it may not work, it is the whole FSM for the 98-02 Accord in pdf.
Clear the code from the memory and see if it comes back.
Check continuity of the transmission range switch as follows.
Remove the electrical connector from the harness, face the terminals to you with the locking tab in the 12 O'clock position. Terminals are numbered;
Row one - 1; 2; 3
Row two - 4; 5; 6; 7
Row three- 8; 9; 10
There will be a tab in the ~ 5 o'clock position between terminals 9 and 10.
Check for continuity(not resistance). Place the transmission in the following gear and check the terminals.
P - 1 & 3, 3 & 10, 10 & 1
R - 3 & 9
N - 1 & 3, 3 & 8, 8 & 1
D4 - 2 & 3, 3 & 7, 7 & 2
D3 - 2 & 3, 3 & 6, 6 & 2
2- 2 & 3, 3 & 5, 5
1- 3 & 4
There is a two page diagnostic for the range switch CEL code.
Row one - 1; 2; 3
Row three- 8; 9; 10
R - 3 & 9
2- 2 & 3, 3 & 5, 5
1- 3 & 4
Verify the pins are not corroded or dirty, if not and the range switch is faulty replace.
If the fluid has never been replaced it will have a slurry feel to it, especially the gunky in the sump, and on the drain plug.
alexkharden
May 18, 2015 07:24 PM
BIO Hazard
Jun 2, 2011 06:24 PM
bob2000
Apr 23, 2005 06:18 PM
andyep3
Jul 23, 2003 01:34 PM
