Transmission problem.
Old Feb 28, 2015 | 11:44 PM
macmilla's Avatar
Default Transmission problem.
Please pals, which sensor could be responsible for delayed 1-2 and 2-1 shifting in accord 2001 4cyl.
Old Mar 1, 2015 | 02:35 AM
Mikhail's Avatar
Default Re: Transmission problem.
Idk maybe the clutch is going out or something. Those transmissions got issues from that year.
Old Mar 1, 2015 | 05:03 AM
jdmeg6118's Avatar
I think the op is referring to a automatic transmission vehicle.
Old Mar 1, 2015 | 05:59 AM
Mikhail's Avatar
there are clutches inside a auto trans...
Old Mar 1, 2015 | 11:00 AM
MAD_MIKE's Avatar
MM Gruppe B
Nein.
Check the 2nd gear pressure sensor.
Located below the distributor, screwed into the transmission.
If the sensor is gummed up, leaking, or the wire harness is damaged it will cause a delay in 1-2 and 2-1 shifts.
Old Mar 1, 2015 | 11:24 AM
xci_ed6's Avatar
No codes?
How's the fluid?
Old Mar 1, 2015 | 08:59 PM
macmilla's Avatar
yeah, no code.
New fluid, not burnt.
Problem is worse when the car has been driven for about 20min. better when cold.
Old Mar 1, 2015 | 09:06 PM
macmilla's Avatar
Originally Posted by MAD_MIKE
Nein.
It seems to be intact but I'll observe more closely later today.
Eric McBride
Jan 10, 2018 01:54 AM
Foxracingfreak
Transmission & Drivetrain
Oct 18, 2015 03:40 AM
george taylor
Sep 5, 2012 07:55 AM
SIDreamer
May 2, 2011 09:51 AM
2ToneEM1
Oct 9, 2008 12:03 PM
