92 eg cx headlights wont turn on.
Old Feb 28, 2015 | 04:39 PM
her92eg's Avatar
Default 92 eg cx headlights wont turn on.
I have ebay hid's i checked all the wires and also checked the fuses. Other than the switch itself i have no idea what to look for. And even how to tell the switch is bad other than buying a new one. My corner lights work just nor my low or high beams.
They have been turning off randomly the past few weeks. I have no idea if that means anything. Please help.
Old Feb 28, 2015 | 05:52 PM
Ej8 d16's Avatar
Default Re: 92 eg cx headlights wont turn on.
Have you checked for bad ground connections?
Old Feb 28, 2015 | 06:14 PM
her92eg's Avatar
No, i don't know how to. How would i go about that?
Old Feb 28, 2015 | 06:17 PM
Former User's Avatar
With the light switch on set at low or high beams, test voltage at fuses 9, 10, 21, and 22 using a multimeter. Click the Fuses link in my signature.
Old Feb 28, 2015 | 07:33 PM
HOMEMADEPOWER's Avatar
I had da same problem. I cleaned the headlight/corner light ground cable and that fixed the problem.
Old Feb 28, 2015 | 09:19 PM
xci_ed6's Avatar
yup, a relay test will tell you a lot!
Old Feb 28, 2015 | 09:44 PM
NotARaCist's Avatar
I never narc'd on nobody!
eBay HIDs. Your ballasts might be failing.
http://www.acuitybrandslighting.com/...ets/td-110.pdf
Old Feb 28, 2015 | 09:55 PM
her92eg's Avatar
Okay ill test the ground. I was worried it was the ballasts, i hope not. Im traveling and all the original stuff is in a storage building over 400 miles away.
HondaTom87
Sep 9, 2011 07:31 AM
vanilla gorilla
Aug 6, 2010 10:49 AM
eghatchfla
11
Jul 1, 2010 06:15 PM
nudvl
18
Feb 24, 2007 09:57 PM
