map sensor reading on scanntool question
Old Feb 26, 2015 | 03:11 PM
hillbillycivic's Avatar
Icon2 map sensor reading on scanntool question
did a test on my map sensor with the vacume pump rental tool at advance auto parts. the vavume and voltages matched what the specs showes thet should be.
i used 2 scantools mine and a friends and they both show 8inhg at idle but a vacume gauge hooked up to the booster hose shows 19inhg at idle
so why is the output voltage correct for the vacume but the scan tools show different
issue is strange power band and rough idle (new iac do to last one totaly failing)
Old Feb 26, 2015 | 03:35 PM
Default Re: map sensor reading on scanntool question
what change am i looking for when i apply vacuum to the regulator?
and how does that affect the vacuum?
aligntv
Feb 14, 2017 06:16 PM
mtdineen
Oct 18, 2014 01:58 PM
Clayton
Nov 28, 2006 07:36 PM
FERIOkid
Nov 11, 2006 04:07 PM
Ri5e
10
Sep 6, 2004 05:11 PM
