Parking brake adjustment
Old Feb 26, 2015 | 02:21 PM
mikeybee95's Avatar
Default Parking brake adjustment
I just finished my rear disc conversion on my 98 civic coupe. I used Integra rear trailing arms and calipers. I replaced literally everything, down the the dowel pin for the parking brake. I ordered brand new 99-00 si parking brake cables. Now my problem is that even with the hand brake full loosened, my drives side cable is pulled tight and the wheel is locked up. Is there a way to free up just one side? On the caliper?
Old Feb 26, 2015 | 02:24 PM
slomofo's Avatar
GDD Member
Default Re: Parking brake adjustment
I could be wrong, but I don't believe there is individual wheel adjusters, only an adjustment at the parking brake lever itself.
Could it be possible that you routed the cable incorrectly causing it to stretch?
Old Feb 26, 2015 | 03:09 PM
mikeybee95's Avatar
It's quite possible since they were coiled up from the package. But I loosened all the mounts and made sure it had some slack in it. It just seems as the cable short. It could also be possible that I have the on the wrong sides. But I looked and the drivers side is only 3/8th shorter. So I don't see how that would make much of a difference
Old Mar 3, 2015 | 05:58 AM
mikeybee95's Avatar
Figured it out. The driver side caliper (which was replace for a reman from autozone) the parking brake pin was seized. Replaced the caliper and its working properly now
trakwhore
Suspension & Brakes
Nov 19, 2008 06:49 AM
bopbop93030
Jul 7, 2008 12:26 AM
Nisif
Jun 6, 2008 07:43 PM
Kennydee
Oct 29, 2006 08:22 AM
Turbo Dan
Aug 8, 2006 07:05 AM
