1998 Honda Civic EX running too cool
Old Feb 25, 2015 | 07:31 AM
pityocamptes's Avatar
Default 1998 Honda Civic EX running too cool
Its been about 30-40's (degrees) at night in the morning lately. I noticed last night while driving a few miles that the vehicle was not heating up at all. Turned on the heater control and air was mild at best. Got home, after driving about 4-5 miles, and vehicle was barely about 1/4 way up the temp gauge. Hoses were warm - bottom and top, and both were also soft / felt like no pressure.
Not sure if the cap is bad, looked at it and it seemed fine. Replaced the cap this morning. Thermostat is less than a year old. Weird... will see if the new cap makes a difference. No blown head gasket (before anyone chimes in), no water in oil, runs great...
Old Feb 25, 2015 | 07:45 AM
testify's Avatar
On vacation
Default Re: 1998 Honda Civic EX running too cool
Your thermostat is stuck open.
Old Feb 25, 2015 | 08:15 AM
White_EG1's Avatar
Originally Posted by testify
Your thermostat is stuck open. Replace it.
Old Feb 25, 2015 | 08:54 AM
Damn!!! Just did it too only a few months ago... shitty after market parts...
Old Feb 25, 2015 | 09:06 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Thermostats are one of the ones that non OEM always seem to have problems. I see this time and time again on here and it's always non OEM thermostats that cause grief.
Old Feb 25, 2015 | 09:41 AM
Thanks. Been a while, can't remember if I need any RTV sealer if the rubber gasket is fine? It's (thermostat) behind the engine near the intake, right?
Old Feb 25, 2015 | 09:54 AM
turbohatch96y7's Avatar
Had a thermo stuck open once and caused the motor to overheat too
Old Feb 25, 2015 | 10:11 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
On the 92-95 the manual doesn't call for any Hondabond. I just replaced my wife's thermostat (yes behind the dizzy on the intake side) as her's was leaking a little. I had to wire brush the mating surface to clean off the build up of dried coolant.
Also note, the torque on those bolts is very little. The 5th gen is 7 ft-lbs. I did 10 as my inch pound wrench's lowest setting is 120 inch pounds.
Fixed the leak and the car is doing fine.
Don't forget to burp the car properly. Raising the nose of the car helps and is not in the manual.
And since you are there, you should unbolt the ground on the thermostat housing and clean up any corrosion with a wire brush and put it back on. Just a good thing to do since you are working right there.
Old Feb 25, 2015 | 10:16 AM
09chaplak's Avatar
Loves Tossing Salad
When I replaced mine a little while ago I hadn't put an RTV on the metal contact points and it starting leaking a tad bit. I took it apart again and added a little around the sides which fixed the leak. Probably not a bad idea if you have some.
stevenrankin20
Aug 23, 2016 05:47 PM
petrosar
May 31, 2016 06:54 PM
shamilton1975
Mar 27, 2015 11:30 AM
50cool50
20
Apr 1, 2011 01:47 AM
