92 Accord Hard Start
Old Feb 25, 2015 | 03:58 AM
benrock19's Avatar
Default 92 Accord Hard Start
I have a #6 check engine code wich is for the ect not sure if it will cause the hard start and shitty idle when its cold but when its warm i only just have to bump the starter and it runs smooth
Old Feb 25, 2015 | 09:07 AM
Rtype16's Avatar
Default Re: 92 Accord Hard Start
A lot of fueling calculations are based off the coolant temperature sensor. Especially when starting the car cold. Replace the sensors and it will go away.
Old Feb 25, 2015 | 08:59 PM
benrock19's Avatar
Sensors? I thought there was just one located just left of where the upper radiator hose meets the block?
Old Feb 26, 2015 | 11:57 AM
holmesnmanny's Avatar
The ect is the two prong sensor under the distributor.
Old Feb 26, 2015 | 06:32 PM
benrock19's Avatar
Thank you for the location I took a look and both the wires were not conected to the plug so i robed a plug off a junk harnes i had and now it starts and idles fine
bwk
Dec 29, 2017 04:49 PM
MasterNewb96
Mar 3, 2016 04:10 PM
help wanted
May 1, 2015 01:30 PM
MrMagic81
Nov 19, 2012 03:22 PM
bochnak
Nov 11, 2010 04:42 AM
