94 Honda accord fuel problems
Old Feb 21, 2015 | 08:06 PM
jrwebstar's Avatar
Default 94 Honda accord fuel problems
I got a 94 Honda accord it gets fuel all the way to the fuel rail it has a spark on all the plugs the problem is it gets fire but it acts like it don't have enough fuel to stay running and also there is oil all over the plug wires in there holes any body got any ideas
Old Feb 22, 2015 | 04:43 AM
Lost Again's Avatar
Default Re: 94 Honda accord fuel problems
Are you getting a good blue spark at the plugs?
For the oil on the wires, the tube seals are leaking.
Old Feb 22, 2015 | 07:59 AM
jrwebstar's Avatar
Yea they have a blue spark somebody told me that maybe the fuel injectors got clogged up our it jumped timing but I'm honestly not sure how to check either of those
Old Feb 22, 2015 | 10:11 AM
faithster1's Avatar
Seems like your in need of some Spark plug tube seals, might as well get the valve cover gasket kit while your at it.
As for your fuel problem. First check your fuel filter. Then you might want to do a fuel pressure test to rule out any faulty fuel pump issues or possible clogs(Fuel lines)
You can rent the tools at most autozones or oreilly autos
Old Feb 22, 2015 | 10:34 AM
jrwebstar's Avatar
I disconnected the fuel line from the fuel rail and turned the car on and it had a pretty good steam of gas coming out of it
Old Feb 22, 2015 | 10:41 AM
jvr's Avatar
jvr
For the oil in the spark plug tubes, you'll need to replace the upper AND lower spark plug tube seals. They come with the valve cover gasket kit that you can get at any auto parts store for $15-20. To replace the lower seals, you'll have to remove the rocker arm assembly and then do a valve adjustment afterwards.
Old Feb 22, 2015 | 03:22 PM
faithster1's Avatar
There could be a stream, but if no pressure is present then you cant get the right amount/if any of fuel into the injectors.
1997boostedeg
Apr 15, 2012 11:15 AM
tkda
16
Mar 17, 2009 09:58 AM
91da_teg
Jan 21, 2009 11:16 PM
