3rd gear grinds
Old Feb 19, 2015 | 09:37 AM
masospaghetti's Avatar
Default 3rd gear grinds
I get a slight nick / grind shifting into 3rd gear sometimes. I already am using GM Synchromesh FM fluid. All other gears shift nice and smooth.
Tricky thing is - I just put a new synchro and bearing kit into this transmission, and it still has this grind.
Any tricks to try? Any fluids to try?
93 Accord w/ H2A5 transmission. Thx all.
Old Feb 19, 2015 | 02:54 PM
GoodUsername's Avatar
Default Re: 3rd gear grinds
You could have a bent shiftfork. I don't have experience running GM fluids, I know Honda recommends either theirs or a motor oil. Fluids aren't your problem, it's either something in your linkage, a bad fork or something went wrong in your overhaul. What exactly was in the kit/did you replace?
Old Feb 19, 2015 | 03:24 PM
burnoutboy's Avatar
The Credible Hulk
Bleed the clutch and then check for clutch drag. PP could be ****, flywheel could be warped.
Old Feb 19, 2015 | 03:35 PM
Can a bad pressure plate or bad flywheel cause an intermittent grind in only one gear?? That's not my understanding.
Old Feb 19, 2015 | 05:56 PM
holmesnmanny's Avatar
It sounds like it had the grind before you did the rebuild. Did you take any pics of the assembly ? It's best to take pics and have a reputable tranny part dealer tell you what should be replaced. With a grind it should be visible when you do a tear down what the issue is. I'm assuming you replaced the rings ?
Old Feb 20, 2015 | 04:22 AM
Yeah I replaced the synchro rings and I did mic all of the shafts to make sure they were within limits per the Honda overhaul procedure.
I did notice that the teeth on the sliders had wear on them, rounded over. I assume that is where I messed up and should have used new parts. Unfortunately I did not take pics of the individual parts, just the assembly.
Old Feb 25, 2015 | 07:45 AM
Will I starve anything for lubrication if I try a heavier oil? Something like 10w-40 instead of 5w-30?
Old Feb 25, 2015 | 09:53 AM
If you dont use honda mtf, which is the best thing you can use, you should be using 10-30.
Old Feb 25, 2015 | 11:29 AM
Id really suggest going to honda mtf and seeing if that helps you.
Old Feb 25, 2015 | 01:56 PM
slippedwrench's Avatar
you still have a mechanical problem of some kind.. something bend warped or worn..only a visual inspection will solve this problem.
Old Feb 25, 2015 | 02:05 PM
Ya the honda mtf wont fix it but it should help somewhat
Old Feb 26, 2015 | 05:59 AM
jvr's Avatar
jvr
Just wanted to share my experience. I have a '94 accord lx with mt, and while it didn't grind, it was a B#TCH to get it into first or reverse. It just wouldn't go into gear (even when completely stopped) unless I put it in neutral and blipped the throttle first, and even then sometimes it took several attempts. I was convinced there was a mechanical problem but I replaced the fluid with Honda fluid first, and it completely solved the problem. It's been about a year and it's just smoother all-around.
Old Feb 27, 2015 | 10:11 AM
Thanks for the inputs.
I didn't realize that the correct lubricant is 10w-30 oil, I thought it was 5w-30. I looked it up and it appears that Honda MTF is also 10w-30. The GM Synchromesh is 5w-30. I ordered some or the Honda MTF and will try that and see how it improves.
Hopefully the grinding is related to the oil being too thin when cold, when the grinding is worse.
VeeSykkz
Aug 13, 2014 08:36 PM
Ricextacy
Transmission & Drivetrain
13
Mar 17, 2009 07:57 AM
igotboost
Jul 30, 2006 06:23 PM
BLK99VTECR
15
Oct 6, 2004 11:20 AM
tyflip2
10
Nov 14, 2003 11:49 PM
