Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
The dreaded 3rd gear grind. just had clutch replaced.
Old 08-11-2014, 06:36 PM
VeeSykkz's Avatar
Default The dreaded 3rd gear grind. just had clutch replaced.
So the story of my 666 continues. Bad clutch and broken flywheel $2445, breather hose $30, rear main o ring, power steering sucking air bad o ring, and now I fear 3rd gear synchro has taken a beating. What can I expect and do to prevent future damage? Estimated repair cost?
Old 08-11-2014, 07:15 PM
johnnyb588's Avatar
Default Re: The dreaded 3rd gear grind. just had clutch replaced.
I've never found a good solution to avoid the occasional grind in 3rd, sorry. However, I can help you out with a replacement estimate. I did clutch, flywheel, and tranny swap all at once for $3500 through a local shop.
Old 08-12-2014, 06:07 AM
My Name is Nobody
MSchu's Avatar
I changed to Amsoil fluid in my old 6-6 and my grind went away completely.
I did this at about 8k miles new and I never looked back.
Old 08-12-2014, 07:10 AM
94vtecmn's Avatar
Coming up on 139k using AmsOil, same result, no grind.
Old 08-12-2014, 08:08 AM
johnnyb588's Avatar
Looks like I might need to give Amsoil a try. My current 3rd gear isn't nearly as bad as my old one. It grinds probably around once a month, pretty much at random. Before I had the tranny replaced, it would grind about every other day the first time I shifted into third for the day, and then intermittently between then maybe 1% of the time. It usually wouldn't happen if I babied it in, but even that wasn't enough, occasionally.
How bad is your grind, VeeSykkz? And how bad was the grind for everyone else?
Old 08-13-2014, 06:22 PM
No Big Whoop
Spaceballsthelunchbox's Avatar
Dang, not being able to work on your own car really does cost.
Old 08-13-2014, 08:36 PM
VeeSykkz's Avatar
I can usually feel whether it's seated in gear or not. If I suspect I just pull back and do over to be sure. It happens rather rarely I'd say, but I'm still breaking the clutch and the while car in.
I haven't checked the tranny oil yet, but will surely use high grade lubricants. I always have.
gabe768
06-07-2010 03:06 PM
4everVtec
03-09-2007 12:23 AM
phoenixR
12-26-2002 06:02 AM
Brandon
07-31-2002 09:59 PM
hooptie157
05-20-2002 07:31 AM
Quick Reply: The dreaded 3rd gear grind. just had clutch replaced.
