1996 honda Civic CX squeels like a pig when turning!!..
Old Feb 18, 2015 | 09:39 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default 1996 honda Civic CX squeels like a pig when turning!!..
Ok long story short i picked up a 96 civic cx hatchback. It came with no power steering as i believe they did not come with power steering. It had the same squeel when you turn the steering wheel with the maual rack. So i went down to the local junk yard and had a 99 civic power steering conversion put on. I left with the steering sound pretty much fixed besides a bad alighnment but the sound was gone. A few days later the sound comes back. I looked at the power steering resivour and the hose from the pump to the resivour had a small tear and was leaking. So since the tear was right at the end of the hose i pulled it out and cut that portion of the hose off and put it back on the pump. I tried to bleed the air out by turning the wheel left to right all way to lock about 20 times and it seems bled cause theres no real bubling or foaming going on in the resivour but the stupid sound is there when i turn the steering wheel. It sounds like metal grinding on metal its real loud and annoying. One note i took is when its on my driveway and i turn the steering wheel with the motor running the sound is not nearly as much as when the car is level. It might squeak just a lil bit here and there as im turning the wheel but when its level its a night mare. I still have good power assistance and the power steering seems to be working but i think i narrowed the sound to the new power stearing rack. I hope its not bad but it did come from the junk yard. If anyone has any input on what i should try or check lmk thanks.
Old Feb 19, 2015 | 08:20 AM
slomofo's Avatar
GDD Member
Default Re: 1996 honda Civic CX squeels like a pig when turning!!..
Is it a squeal or a squeak? If it's a squeak and the noise was present with the manual steering rack, I would look towards your ball joints.
For a squeal, I don't know.
Old Feb 19, 2015 | 08:58 AM
tony_2018's Avatar
Fish Twig
bushings probably.
Old Feb 19, 2015 | 12:28 PM
wunfstgsr's Avatar
Loved
Community Favorite
Its more a loud squeak! between the sound of old rubber/ metal grinding.
Another note io took is that even going straight and going over little bumps here and there on the road the squeak is there ! so it does it when the suspension goes up and down and when i turn the steering wheel. Im starting to think could it be lower ball joints? i tried stepping on the side of the door jam and using my weight to bounce the car up and down but i don't hear the squeak its when i turn the wheel whether if its at a full stop or rolling.
Old Feb 19, 2015 | 12:42 PM
testify's Avatar
On vacation
You probably have a rock stuck between your rotor and it's backing plate, or the rotor is contacting the backing plate when you turn.
The lug nuts on your wheel are probably loose.
Old Feb 19, 2015 | 12:52 PM
wunfstgsr's Avatar
Loved
Community Favorite
Ok I'm pretty sure its the lower ball joints now from more research on the symptoms of bad ball joints, i found this video that has the same exact sound and issue as my car so every one says it is his lower ball joints!
Old Feb 20, 2015 | 10:48 AM
wunfstgsr's Avatar
Loved
Community Favorite
So i jacked up the car and i poked a hole in the rubber boot of the ball joint and inserted a straw and sprayed wd40 inside and pulled out the garage and the sound is gone so the ball joints need to be replaced even worse whoever put them on diddnt put the coder pin in smh!
Also my left head light likes to not come on and i have to keep flicking the head lights on and off for it to come on, Im thinking its the cheap *** hid lights i got on but idk.
Old Feb 20, 2015 | 10:55 AM
testify's Avatar
On vacation
I seriously hope you understand you need to park the car until the ball joint is repaired.
If not for your own safety, for the safety of everyone else you encounter on the road.
Old Feb 20, 2015 | 11:02 AM
slomofo's Avatar
GDD Member
Cool, glad you got it figured out.
Old Feb 20, 2015 | 11:41 AM
wunfstgsr's Avatar
Loved
Community Favorite
I under stand it can give but at this point i have no choice i need to drive to work till i can get to it next weak.
Old Feb 20, 2015 | 11:44 AM
testify's Avatar
On vacation
A pickle fork, a gear puller, and a hammer (all of which can be purchased extremely cheap) makes that a 20 minute job, and the part costs $5-$10.
No excuses.
Old Aug 2, 2015 | 08:08 PM
wunfstgsr's Avatar
Loved
Community Favorite
No excuses.
Well I just ended up buying a set of snap ring pliers and the part and used a hammer to knock it out and knocked the new one in with a big socket. I could of rented the tool but i diddnt have $100 to rent it so it was fine. Now i just need to figure out why it burns so much fuel, a tune up is much needed with this beet up engine.
Old Aug 2, 2015 | 08:23 PM
eghatch9295's Avatar
Stancetard Hate Monger
snap ring pliers arent necessary for that little guy, picks/cotter pin tool always work.
Old Apr 27, 2016 | 01:39 PM
stupidchicken03's Avatar
BALL JOINT NOISE!!! - YouTube
Yes I know im bumping an old thread, but im 99% sure this is my issue. Thank you for finding and posting this vid!
Joined the site today just so I could search around and possibly find an answer.
(Ive got a 99 Civic EX)
Old Apr 27, 2016 | 02:10 PM
Former User's Avatar
FYI^ - A bent wheel splash guard that rubs on the brake rotor is another common cause.
Old Apr 27, 2016 | 02:19 PM
jdblock's Avatar
Don't you have a mechanic that lives with you?
Old Apr 27, 2016 | 03:12 PM
Yes I read that too, it is another thing to check, but I doubt that's it. Mine sounds almost identical to the YT video I quoted. While driving or at a dead stop.
Thanks
Old Apr 27, 2016 | 03:14 PM
Hahahahaha what's up John!
I thought about hitting you up to pick your brain since I knew you were/big in Hondas. Just saw your updates with the current car on FB. You still in/around Pville?
Yup, brandon is still with me! I'll only bother him if I need to since he works on cars all day lol. Did you hear he sold the rsti?
Old Apr 27, 2016 | 03:44 PM
jdblock's Avatar
My guess would be a wheel bearing.
Did he get tired of breaking axles?
Old Apr 27, 2016 | 05:46 PM
Gunna shoot ya a txt tonight, im not so sure its ball joints anymore
Haha, naw he only broke em that once. He told it to a friend, and ordered a Ford Focus RS :D
noahs_ark
Honda Civic (2006 - 2015)
Sep 12, 2016 05:25 PM
Prypiat
Aug 19, 2013 09:16 AM
marylou
Aug 10, 2010 08:58 AM
krysted9354
11
Nov 28, 2008 10:25 AM
CWBETB
Mar 27, 2008 03:08 PM
