problems with 92 civic hatchback d15b7
Old Feb 18, 2015 | 12:23 PM
lil_dp's Avatar
Default problems with 92 civic hatchback d15b7
I'm having a problem my car want stay running use to start and run for about 15-20 mins and then it would star jerking and missing like it was flooding and totally die if you put it in gear but if you give it fuel and stuck it in gear quick it would go until you take ur foot off the fuel. But now it want start at all and you can smell gas from some were I'm puzzled anyone got info
Old Feb 18, 2015 | 12:40 PM
24TEN's Avatar
PHANTOM MENACE
Default re: problems with 92 civic hatchback d15b7
Check engine light on? Last tune up?
Without really any info, maybe start by checking the specs on the TPS.
Old Feb 18, 2015 | 12:41 PM
NotARaCist's Avatar
I never narc'd on nobody!
https://honda-tech.com/honda-civic-d...sting-3002401/
Try again.
Old Feb 18, 2015 | 01:06 PM
lil_dp's Avatar
No check engine light which makes me think it ain't a sensor and I'm not sure last tune up idk its got me puzzled I'm about to just swap it out
Old Feb 18, 2015 | 01:12 PM
Former User's Avatar
Thread gets locked without car and engine information.
Does the CEL work?
If you don't know when the last tune up was, then do one (plugs, wires, cap, rotor, fuel filter).
Old Feb 18, 2015 | 01:14 PM
NotARaCist's Avatar
Ah yes, the ultimate form of "I'm just going to throw money at it". Why did you even bother creating a thread if you A - aren't willing to follow the rules, B - aren't willing to do simple diagnostics, and C - don't plan on listening to people who give you advice? Don't waste our time.
Old Feb 20, 2015 | 03:07 PM
lil_dp's Avatar
Sry for bad info.
Its a 92 civic hatchback d15b7.
Just put new fuel pump and plugs wires and fuel filter cap rotor button new distributor in about 5 months before it messed up
Old Feb 20, 2015 | 03:11 PM
NotARaCist's Avatar
Does the CEL come on for 2-3 seconds when you turn the key to ON(II), and then turn back off, or does it not come on at all?
Buy/borrow/rent a spark tester, and use it. Tell us what color your spark is. Given your current attitude towards working on the car, I'm going to guess you either bought the cheapest distributor you could off eBay, bought the first used one you could find on CL without half a clue as to where it came from, or drove to the nearest parts store and bought whatever they had in stock. Did you replace the distributor with a new OEM unit, or one of the other aforementioned options?
Have you done ANY diagnostic tests at all?
RobertoHdz
14
Oct 10, 2018 01:15 PM
Forgotten_0182
Jan 23, 2008 01:09 PM
PACT man
Jan 10, 2007 06:47 PM
JohnD1079
Jan 9, 2007 05:26 PM
Hoppa
19
Apr 18, 2005 07:57 AM
