92 Civic won't start until engine light turns off....
Problem....... 92 civic 130,000 thousand miles, been a great car no major problems engine wise, just normal stuff ie. starter, slave cylinder, alternator.
I turn igniton to acc and the engine light comes on, but won't go off, and the car will not start it will turn over but thats it. After a few minutes, it varies from 1 or 2 minutes al the way up to 10, you hear the fuel pump whirl and the engine light goes off and the car will start no problem.
I jumped the fuel pump, so it funs on acc all the time, still not starting; the engine light still on by the way. I check the Main Relay, not that still same thing. Ive tested the Map sensor and checked all fuses that I could think of.. My next thought was the ECU, but before i go and buy another one i was hoping someone else had any idea about what it could possibly be.
The only problem with the engine is that it has low compression and needs a new set of rings, other than that its all good...
Let me know...
Let me know...
Re: 92 Civic won't start until engine light turns off.... (Forgotten_0182)
You need to find out what code is causing the check engine light to come on.
use this thread:
https://honda-tech.com/zerothread?id=682412
use this thread:
check ur CEL what code? check this out....
https://honda-tech.com/zerothread/1901557
ballbuster4u
17
09-20-2019 07:01 AM
electrones
Honda Civic (2006 - 2015)
10-24-2013 03:03 AM
osbunjosh
12
03-03-2013 12:20 PM
