Compression readings - need advice
Old Feb 16, 2015 | 09:35 AM
angrytriple's Avatar
Default Compression readings - need advice
Dry test 1 2 3 4
180 175 140 115
Wet test 1 2 3 4
240 300 200 180
1993 civic ex - just swapped in a d16z6, from idle to 2500 rpm it misfires and after that it seems to run okay, thinking stuck rings? But cyl 2 doubled in comp. , is that norMal?
Old Feb 16, 2015 | 09:45 AM
White_EG1's Avatar
Default Re: Compression readings - need advice
Looks like you have a piston issue across the board. And No that's not normal.
Old Feb 16, 2015 | 11:02 AM
joey1320's Avatar
If you went crazy with the amount of oil you put in the cylinders, then yes, your compression could easily double like this one did.
If I was you, I would run the engine, let the oil burn off and then do another compression check.
Looks to me like this engine is going to need some internal work.
Old Feb 17, 2015 | 08:05 AM
rockycat's Avatar
Dry test is just that, wet is add oil to a cyl and crank the engine over a few times to mist the oil in the cyl then check.
Old Feb 17, 2015 | 08:18 AM
B20VtecVillain's Avatar
Looks like Cyl 3-4 are having issues, and internal work is warranted. The 300 reading on cyl 2 could easily happen to an otherwise healthy engine if you got a little heavy with the oil or didn't cycle it enough after adding oil. In any event, anything under ~165ish dry is no good and we would reccomend opening it and taking a look.
Type 56
Oct 12, 2016 11:10 AM
jdmwarrior
13
Jan 30, 2013 08:30 PM
Spec R
Apr 18, 2005 11:09 AM
km2323
Mar 20, 2004 11:42 PM
crx1856
Oct 11, 2003 11:11 AM
